06-23-2005, 06:47 PM | #1 |
Newbie Join Date: Sep 2004 Location: denville , new jersey
| jugg axles
i have a set of txt axles and a set of jugg axles , i have posts about people changing the jugg inputs to work like txt inputs but havnt found actual parts that i would need so to not have to order multiple times do i only need the input shafts or is there somthing else i would need to also get before i can use revo shafts with these axles. thanks
06-23-2005, 09:01 PM | #2 |
Moderator Join Date: Apr 2004 Location: In my head
You will need to get the bearing that fit the txt input they are different for the ones for the jugg. I think each input needs a 11x6 and a 11x5 mm bearing. You can also replace the one in the trans with one from a txt.
06-26-2005, 01:19 PM | #3 |
Rock Stacker Join Date: Mar 2005 Location: planet earth
to make jugg axles like txt axles depends alot on the gen of the jugg axle. i had gen 2 axles whiche have the larger top gears then the gen 1's do. you will need to get the parts bag for the txt style inputs and each axle takes 2 of the larger bearings http://www2.towerhobbies.com/cgi-bin...?&I=LXCAH8&P=7 and the rear of the shaft takes the standard bearing you had to start with or bushing. http://www2.towerhobbies.com/cgi-bin...6&I=LXUR39&P=K is needed as well if your tranny is a gen 1 and not a gen 2 mine was a gen 1 so you need the bag for the shortest of the gears. http://www2.towerhobbies.com/cgi-bin...?&I=LXCAH3&P=7 is the bag you will need to convert axles to txt style . i hope this helps out some in a way for me to find some of the parts when i did my conversion had to hit ebay to find the parts i needed http://stores.ebay.com/WalawalaStore...Q3amesstQQtZkm has alot of parts for the jugg/txt if you cant source them any other way. shippin is fair and pretty quick for coming overseas. http://www2.towerhobbies.com/cgi-bin...?&I=LXUR36&P=7 is also needed if your jugg axles are gen 1 and not gen 2 http://www2.towerhobbies.com/cgi-bin...?&I=LXUR42&P=7 is the larger gears i mentioned before for the best conversion. i was able to get just the gears from walawala on ebay i got a extra set "just in case" but im pretty sure i wont need to use them any time soon. Last edited by powertuned; 06-26-2005 at 02:02 PM. |
06-30-2005, 04:39 PM | #4 |
hey thanks alot i just bought a few things from that walawalastor on ebay hopefully i got everything great prices. now i just have to hope tower gets the axle cases in soon thats all i need . thanks
