Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Grave Digger...
Old 01-20-2008, 11:41 PM   #1
Default Grave Digger...
Now its down to the small stuff paint the cage,pick up my 9tooth for the motors,put it back together and to make sure that all the nuts and screws are tight
Bigsky is offline   Reply With Quote
Old 01-22-2008, 06:47 PM   #2
Looks good. I have the same shell, different paint. I'll keep mine nice though, to much work in the paint job.
The full cage is nice. I'd put a couple of more verticles in, but I end up upside down a lot.
hairba11 is offline   Reply With Quote
Old 01-23-2008, 02:31 AM   #3
Thanks this body has been beaten but still in one piece ....just need to tie up a few loose ends on it and wait for the snow to melt off a bit...
....had to paint it digger green
Old 01-23-2008, 08:12 AM   #4
You plan on painting the chassis too? that would be cool. get the whole thing in digger green. I'd rough up the aluminum with so 100 grit to get it grooved enough to hold onto the paint for a while.
Old 01-23-2008, 04:09 PM   #5
no not yet i just want to enjoy it but as soon as it breaks something that requires me to tare it down then yes i will paint the chassis
Old 01-23-2008, 09:42 PM   #6
Hey Bigsky?? you should check out the Montana section down at the bottom of the forum list we're in the regional section under West
JEracing is offline   Reply With Quote
Old 01-24-2008, 12:29 AM   #7
cool will do
Old 02-16-2008, 08:38 PM   #8
Talking
its out side....
Old 09-28-2008, 11:04 PM   #9
Nice rig! I've always been a GraveDigger fan! Just 1 question...why do you have some of the tires going in 1 direction and the other going the opposite direction. For example the drivers side tire is on correctly but the passenger side is on backwards? is this a traction trick or is it just putting the wheels on too quickly?? If it's the latter, then do feel too bad because i've done it on my tmaxx a few times! Otherwise you might just want to put them all going the correct direction if it doesn't help with anything.
nothinbutpower is offline   Reply With Quote
