Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Reverse Wiring On TXT-1
Old 08-27-2004, 10:48 AM   #1
Default Reverse Wiring On TXT-1
I have read that some of you are reversing the wiring to the motors, so that you can run the battery pack up front. That would cause the motors to reverse it's rotation. I have just seen these motors and was wondering if this would do the same thing without altering the wiring? Also would you want to buy these motors over their counterparts?
http://www2.towerhobbies.com/cgi-bin...XW929&P=ML
Distressed is offline   Reply With Quote
Old 08-27-2004, 11:11 AM   #2
Diggin' the new SCX10 II!
badger's Avatar
Default Re: Reverse Wiring On TXT-1
You are correct. That would be a good buy since you would not have to wire the stock can motors in reverse.
I have wired my stock txt can motors in reverse and they run HOT. So does my ESC without a fan. So if you buy a reverse motor then your elctronics should last longer since they should run cooler.
I am getting a mammoth gear reduction next week, does anyone know if I need a normal rotation or a reverse rotation motor for that? I don't know if the gear reduction reverses things with the gears.
badger is offline   Reply With Quote
Old 08-27-2004, 11:20 AM   #3
Hey thanks Badger
Old 08-27-2004, 12:49 PM   #4
With your mammoth reduction, you will need a reverse rotation motor if you keep the motor in front. You would be better off flipping the tranny so the motor is in the rear...then you will need a regular rotation motor, and your battery will be out front helping to keep the front of the truck down when climbing.
schlabinski is offline   Reply With Quote
Old 08-28-2004, 03:07 AM   #5
If you run your motors in reverse you will have heaps less power and much shorter runtimes as well. I did it for a while and dont reccomend it.
Oh yeah and Badger, that new avatar of yours is, in one word, excelent.
TXTFUN is offline   Reply With Quote
Old 08-28-2004, 12:24 PM   #6
Do you think that those new mayhem motors that are reverse rotation will be less power than the normal mayhems?
Old 08-28-2004, 08:46 PM   #7
Nah they are exactly the same, they just turn the other way. You have to use 1 normal and 1 reversed in a clod so they have to be fairly well even.
Old 08-28-2004, 09:34 PM   #8
06 Super National Champ
JasonInAugusta's Avatar
To the best of my memory, the stock silver can Johnsons have 0 degrees timing, which means that they should run the same in either direction.
After all, there's not a reverse-rotation Johnson for the clods.
JasonInAugusta is offline   Reply With Quote
Old 04-18-2010, 01:36 PM   #9
Really?? i was running my txt backwards to have the weight of the battery in the front...and i did not notice anything bad...at first i had the stock motors...then i wired in two trinty speed gems 17 turn doubles with zero degree timing
matrixman is offline   Reply With Quote
Old 04-23-2010, 04:45 PM   #10
j0e
whoah!
six years... is this a record?!?
j0e is offline   Reply With Quote
Old 06-04-2010, 02:53 AM   #11
LMAO!!! I think this is the record
a69baldone is offline   Reply With Quote
