Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: new shocks
Old 09-15-2004, 05:22 PM   #1
Default new shocks
Hey guys I'll get a pick up tonight. nevermind I found one online
A guy a work gave me a set of shocks. I think they're for a T-maxx or other 1/8 scale nitro truck. But they are sweet, the shock shaft is 5mm thick. they've got reseviors and are all aluminum. Smooth as butter too.
Man they are sweet. I think I'll be following Badgers lead and ditching the canti's.
rckjeep is offline   Reply With Quote
Old 09-15-2004, 05:50 PM   #2
Default Re: new shocks
look nice. A camo car with Gold shocks lol.
5mm thats thick 8O
skyjacker_rc_club is offline   Reply With Quote
Old 09-15-2004, 06:26 PM   #3
MODERATOR™
EeePee's Avatar
Cool mang, hopefully they don't leak like these stock leak-O-matics...
EeePee is offline   Reply With Quote
Old 09-15-2004, 06:37 PM   #4
No the one's I got are black w/blue resevoirs. I may just buy black resevoirs later.
we'll see EP
Old 09-15-2004, 09:23 PM   #5
Diggin' the new SCX10 II!
badger's Avatar
Those shocks are sweet looking!
How long are they, and how much travel do they have?
They look like about the same size Integy max shocks I am getting except for the HUGE SHAFT. 8O
badger is offline   Reply With Quote
Old 09-15-2004, 10:27 PM   #6
where you getting them.? im in the market for some shocks
nodnarb22 is offline   Reply With Quote
Old 09-16-2004, 12:44 AM   #7
oh no gold to bad. lol
those things should look great.
i still can beleive how fat thoses shafts are.
Old 09-16-2004, 12:47 AM   #8
So I temporarly mounted the front's. They're a little stiff and I need to move them inside the frame.
Old 09-16-2004, 04:02 AM   #9
AFJ
looks great, really love them!! i bet they costed an arm and leg :(
AFJ is offline   Reply With Quote
Old 09-16-2004, 01:23 PM   #10
They look like Progressive Suspension shocks. Expensive, but strong
CustomCrawler is offline   Reply With Quote
Old 09-17-2004, 10:07 AM   #11
alright I got the rears on last night. They don't seem to be in the way but I lost a ton of flex. The truck sits lower due to a little sag in the shocks. I think I'll try running thinner shock oil (currently @ 40wt.) and the springs are progressive so that doesn't help. I'll try getting some of the softest assoc. springs this weekend. what color would that be anyway?
Old 09-17-2004, 04:12 PM   #12
Clear..........
Spring rate: K=0
BARK is offline   Reply With Quote
Old 09-17-2004, 04:15 PM   #13
thanks for the info, Barksalot!
Old 09-17-2004, 04:29 PM   #14
badger's Avatar
I don't think you want the softest springs, I had to put stiffer springs on my Assoc. shocks and preload them to get the right ride height and firmness to keep the torqe twist down while allowing for the shocks to compress in articulation.
It also depends on how you mounted the shocks.
Being a rookie in the crawling scene, I am sure you will figure it out.
Old 09-17-2004, 05:49 PM   #15
Location: orange county n.y. , building the hydro crawler
I think they are the green ae springs. They are very soft so you will need preload spacers on them but you will have a very linear suspension setup almost no progression ive run them for a while and i like it. I love the size of the shaft how much do they go for new?
sambmx is offline   Reply With Quote
Old 09-17-2004, 07:00 PM   #16
Correct they are Progressive EDC-2 shocks. The shafts are so large because they are actually 2 shafts. The main 3mm shaft and a sleeve. You can adjust the dampening of the shock by rotating the spring cup. without changing pistons or fluid.
CrawlinForLife is offline   Reply With Quote
Old 09-17-2004, 08:20 PM   #17
that would explain why are all not the same. I lost SO much flex. I'm not sure what to do mount them in the stock location or keep trying new locations.
Old 09-18-2004, 12:07 AM   #18
badger's Avatar
Make sure the shocks are not hitting anything during the compression cycle. I had to cut some of the sides off of my battery tray to eliminate the shocks from hitting it which made me loose articulation.
Old 09-18-2004, 12:32 AM   #19
badger's Avatar
Thanks wheels, that would be sweet since I just got my new Integy shocks today. ....
But I will probably sleeping off a hangover most of Sunday after hosting my friends bacholer party at my house Saturday night.
Old 09-20-2004, 12:58 AM   #20
Alright since I lost all my flex I installed the shocks in the stock location. And now they shocks are too soft. go figure the effects of leverage. I'll try and test it tomorrow. Hey Wheels wanna show me that mini hammers trail tomorrow after work?
