Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Experimental TXT Suspension
Old 03-06-2004, 08:19 PM   #1
Default Experimental TXT Suspension
worked on the TXT today and came up with this. Found a great spot to mount the lower part of the savage damper. Will do some extreme testing tomorrow. click the link for pics.
http://www.hpisavageforum.com/forum/...;threadid=9801
DirkDigler is offline   Reply With Quote
Old 03-07-2004, 10:03 AM   #2
Default Re: Experimental TXT Suspension
Looks good, I look forward to reading your write up on it.
rcwild is offline   Reply With Quote
Old 03-21-2004, 05:21 PM   #3
so,,, how did it work
metallicamaxx is offline   Reply With Quote
Old 03-22-2004, 08:06 AM   #4
not good enough....
Old 03-22-2004, 11:54 AM   #5
oh well,, sure looked cool!
Old 04-12-2004, 12:18 PM   #6
Any updates on this? And how did u attach the shocks to the axles? It looks like you put them in the "braces", i tried that with myne and they dont fit...??
Crawler80 is offline   Reply With Quote
Old 04-12-2004, 02:38 PM   #7
I got them working fairly well but not quite as good as the canti set up.
Yes, I drilled a small hole through the truss braces on the knuckles. The rod ends that come with the hot bodies aluminum shocks were narrow enough to wedge in. I also did this with the X factor axles but returned them to the canti set up.
Old 04-12-2004, 04:06 PM   #8
Can you get some pics of your steering?
