Project: ? 95% done NEW PICS 56k warning http://www.nor-calrcrc.com/albums/ra...0057.sized.jpghttp://www.nor-calrcrc.com/albums/ra..._001.sized.jpghttp://www.nor-calrcrc.com/albums/ra..._001.sized.jpghttp://www.nor-calrcrc.com/albums/ra...0037.sized.jpghttp://www.nor-calrcrc.com/albums/ra...0042.sized.jpg here are some pics tell me what you think and check this site out for more pictures http://nor-calrcrc.com/modules.php?s...php&page=1 |
Re: Project: ? 95% done NEW PICS 56k warning I would: 1. Buy 1 Integy lathe motor and ditch the two stock cans. http://www.hobby-sports.com/store.php search for this part # INTSCM5501 2. Buy a gd600 gear reduction. You can swivel the the way you mount it to also fix your odd tranny mount/battery position angles. This will also allow you to run only one motor. You will increase your run times and get WAY more torqe. http://www2.towerhobbies.com/cgi-bin...LXSL79&P=7 3. Make better servo mount's. Your's sitck out too far, which kills your approach angle and put the servo out in harms way. http://www.nor-calrcrc.com/albums/txt_mods/aaa.jpg 4. Buy either Integy MSR4 maxx shocks or XTM shocks and axle mount them. |
Re: Project: ? 95% done NEW PICS 56k warning looks good for the most part. i like that skid plate the bolts on the skid stick out to far. and what badger said i use a tition motor and a gd600 it works good. i dont think you need a lathe motor with a gd600. you could use a 28000 rpm stock motor and gear down . lathe motors are like big blocks tons of torqe great for clods were you cant gear down low . gd gives you all the gear you could want so you can use the stock cans. my 69 camaro has a sbc that gose 7800 rpms :twisted: so i us 4.11 my budy has a 460 that revs 5800 so he uses 373 . the torqe pulls the truck off the line i use gears to get torqe to get me off the line!! its the same for rc |
Re: Project: ? 95% done NEW PICS 56k warning Quote:
The reason I will ONLY run a lathe motor on any truck is because of it being a 55T motor that produces a shit load of torqe and also draws less amps then any typical motor and that gives you longer run times! |
Re: Project: ? 95% done NEW PICS 56k warning gd-600 and a 3.8 on motor and a 16 on the gd-600 gives you so much torqe with the kyosho magnetic mayhem is the best motor for the txt and the run time is about 1hr and 15-30min run time. |
