Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Steering stops on txt axles
Old 02-04-2005, 08:34 PM   #1
Location: Driving the Troysion Stick up the BIG BOY line!
Default Steering stops on txt axles
Anyone remove these? Any issues with removing them?
cheapjeep2 is offline   Reply With Quote
Old 02-04-2005, 08:47 PM   #2
2006 2.2 National Champ
BENDER's Avatar
I haven't bothered to cut them, outer knuckle hits axle housing at the same time. Would have to shave axle housing or knuckles too. I didn't want to cut either one so I left stops on.
BENDER is offline   Reply With Quote
Old 02-05-2005, 07:02 AM   #3
MODERATOR™
EeePee's Avatar
With my Futaba radio I was able to set the limits. They weren't symetrical.
With my Traxxas TQ3 radio, I can't set the limits, and the servo had more travel than the plastic bumps would allow.
I cut the nubs off on the front of the axle only, and gained a little more steering.
It still wants to go a little further...
EeePee is offline   Reply With Quote
Old 02-05-2005, 09:18 AM   #4
Web Wheeling
Etype R's Avatar
I always cut the stops off my juggs and clods. I also grind off the back of the knuckle and on my race clod I even ground the output cut to allow even more steering.
EeePee, if you want to limit your steering and your radio doesn't have the settings for it, just move the steering link to the servo up one or two holes on the servo horn/saver.
Etype R is offline   Reply With Quote
Old 02-05-2005, 09:32 AM   #5
MODERATOR™
EeePee's Avatar
Originally Posted by Etype R
EeePee,...
Got it in the inboardest position, thanks though.
