12-10-2007, 02:42 PM | #1 |
Pebble Pounder Join Date: May 2006 Location: Anaheim
| torque twist, weight distribution
Hello, I thought about putting me lipo packs split up on the axles to remove more weight from the chassis, is this going to help remove some torque twist? Any ideas? this is going to be a general purpose truck, both crawling, and then with some slight changes for higher speed bashing, would love to have it work the best it can. Suspension is getting nailed down, COG is getting nailed down, now its too weight distribution, pros and cons, ideas, go buck wild and share the knowledge
12-10-2007, 04:16 PM | #2 | |
From your other thread, Chrizzly said, Quote:
12-10-2007, 05:02 PM | #3 |
12-10-2007, 08:42 PM | #4 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
I'm running 14 cells on mine, 7 per side in aluminum trays. The trays are mounted even with the bottom of the body almost like rock rails. |
