Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: GPM 4 Link help
Old 07-23-2010, 12:58 PM   #1
Default GPM 4 Link help
Has anyone bought GPM's 4 link (CC161)? I have it and it comes with no instructions and it seems what is provided is either to short or to long lol.
Maybe my set was machined wrong?
Grumpster1980 is offline   Reply With Quote
Old 07-24-2010, 06:53 AM   #2
What kind of body are you running? Pics would help figure the problem out as well.
Killa-Cotton is offline   Reply With Quote
Old 07-25-2010, 07:48 PM   #3
These are the pics from GPM's site, I have the sets but have not yet fitted them so I cant tell you if they are wrong or not
Now looking at this one it looks like they have 2 x longer rod ends and 2 x shorter ones. Are you trying to use either 4 x shots ones or 4 x longer ones together instead of mixing them ?
SMUDGEBUG is offline   Reply With Quote
Old 07-26-2010, 12:04 AM   #4
how much did it cost you to buy this set up???
sid15 is offline   Reply With Quote
Old 07-26-2010, 01:32 PM   #5
Mixing the rod ends seems to be the trick! Thanks! I think the links were $30 or so....
Old 07-26-2010, 11:45 PM   #6
Took some pictures! The GPM 4 link works really well. No binding and with the rear lower shock mounts and you get a little rear lift. The rear lift could be bad by raising your CG and good by giving you more room to articulate. I figure it will help more than hinder. I had my own 4 link set up before but this one seems to work smoother. My poor CC-01 needs a bath and respray! At least it's no shelf queen!
Old 07-27-2010, 09:58 AM   #7
Awesome Grumpster! The pics really help.
Have you thought about possibly mounting the long links to the side of the chassis instead of under so that the rod ends don't get hung up?
I'm going to get me a set too from GPM.
Evandiego is offline   Reply With Quote
Old 07-27-2010, 11:27 AM   #8
That's how I had my custom 4 link That I made set up but this one seems to be smoother. I will have to test it on the rocks and see.
The problem with mounting them on the side is the geometry gets messed up. The GPM links are fairly short and you might not be able to mount them on the side.
Old 07-27-2010, 12:13 PM   #9
I used stock Axial links that I had kicking around. Mounting them in the stock location limits movement and causes major hangups due to them hanging down so low. Mounting them to the side of the frame rails increases movement and ground clearance.
Here is the short WB setup using only Axial for the lowers and what a huge improvement just these make.
blackfoot is offline   Reply With Quote
Old 07-27-2010, 01:05 PM   #10
On the lookout for Rocks
constantmotion's Avatar
That's how I have always mounted my lowers at the chassis. If anyone the geometry is better b/c of triangulation. At the stock location, the wide angle is at the axle for both the upper and lowers.
constantmotion is offline   Reply With Quote
Old 07-27-2010, 07:54 PM   #11
Looks good guys!
Old 07-28-2010, 03:19 PM   #12
Where can I buy the gpm 4 links kit? I've been searching but cant find it
LJ_24 is offline   Reply With Quote
Old 07-28-2010, 03:32 PM   #13
Here ya go, should take you strait to the CC01 section.
http://gpmracing.com.hk/catalog/main...oeg5lqo7oap7g1
BGGruff is offline   Reply With Quote
Old 07-28-2010, 11:45 PM   #14
You can buy them on Ebay or direct from GPM just email GPM and they will email you back a invoice so you can pay them.
Hell just buy them here....
http://www.gpmparts.com/shop/tamiya-...-90016658.html
