01-26-2014, 11:50 AM | #1 |
Newbie Join Date: Apr 2013 Location: Space Coast
| Convert Wrangler bodied CC-01 to Bronco?
Hey guys I have a CC-01 Wrangler set up with junfac links, GPM steering kit, running RC4WD stamped beadlock wheels and 1.55 mud thrashers. Can someone point me in the right direction here. I am thinking of converting this Jeep to the Bronco clear body. I see in specs the body lists mounting hardware included. Is this the plastic stick mounts needed for the body pins that rise out of the chassis tub? If not can someone tell me what all is needed in addition to buying the clear body to mount this on my Jeep? Really have no interest in fabbing up my own or doing anything custom at this time. Just want to make this simple and easy Also from what I have seen they are the same wheelbase is this true or will I need to do any other mods to make this work. I just want to have everything here and ready to go when I start this project. Thanks, David. |
01-26-2014, 10:45 PM | #2 |
| Re: Convert Wrangler bodied CC-01 to Bronco?
Hey guys got it figured out. Wheelbase will fit. Parts needed are: Bronco body, Bronco D parts 19005741 x 1, and Bronco M parts 19115291 x 1 (should be two sets of parts included you need both) in case anyone else was wondering. Kind of pricey though once I added it all up. David. |
01-27-2014, 07:07 AM | #3 |
The Bronco WB is slightly longer. It's pretty close to be honest, about 10mm or so. You might be able to get away without changing anything.
01-30-2014, 03:01 PM | #4 |
Newbie Join Date: Sep 2013 Location: Concord
Please post up before and after? I am thinking of doing same swap.
02-02-2014, 09:12 AM | #5 |
Hey Scott ended up just getting another jeep body and finishing it that way. Bronco is way cool but ultimately would cost too much to do. May end up getting the Bronco kit down the line tough. David. |
Convert Wrangler bodied CC-01 to Bronco? - Similar Threads | ||||
Convert wrangler body to FJ40 | surya.prash17 | General Scale Talk | 2 | 10-09-2009 02:27 PM |
Bronco Bodied, Lizard Footed Bruiser | Crawlin4fun | 2.2 Scale Rigs | 11 | 03-26-2008 01:07 PM |
bronco bodied p4 beater | sloppy | Tamiya TLT Crawlers | 2 | 06-02-2007 08:43 PM |
Bronco bodied computer | twisted84toyota | Chit Chat | 9 | 03-15-2006 07:56 AM |
