06-02-2009, 06:07 PM | #1 |
Newbie Join Date: May 2009 Location: amarillo
| HT225mg dig servo won't fit...?
I just got mine in today and was trying to install some stuff before the motor/rx get here tomorrow and my 225mg won't fit between the trans and the frame. I can wedge it in there but it is extremely tight...shouldn't there be just a touch of room for trans/frame movement? anyone else had this trouble. should i take a little off the frame or maybe off of the servo case?
06-02-2009, 06:12 PM | #2 |
Rock Stacker Join Date: Oct 2008 Location: Tualatin
the 225 mg is a tight fit. had to put the servo mounts on the servo first, then install the whole works. mine is toushing the chassis side plate but it does fit. took somw wiggling to feed it in to place and some determinatin to get the bolts into the trans mount.. hope this helps.
06-02-2009, 06:22 PM | #3 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Same here, but I was able to get it on with the mounts installed first.
06-02-2009, 06:36 PM | #4 |
i was trying with the mounts on it already but was very tight. if everyone else is jamming it in there then i will do the same. thanks |
06-02-2009, 07:13 PM | #5 |
Quarry Creeper Join Date: Feb 2009 Location: Rocklin, CA
Put the mounts on, but don't tighten the screws until you have the trans screws started. I don't see how there needs to be any play since all the gearing is in the axles.
06-02-2009, 07:20 PM | #6 |
Pebble Pounder Join Date: Apr 2008 Location: yakima
i jammed it in there and saw that it was putting pressure one the tranny. all i had to do was file just a touch off the bottom edge of the chasis there and it clears fine. it was almost none at all.
