11-21-2009, 11:27 AM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Holland
| MOA with 2x 17.5 brushless ????
I run my LCC stock with one 17.5 brushless EZRUN. I would like to go MOA with 2x 17.5 brushless motors. Will this work? |
11-21-2009, 11:30 AM | #2 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Yep. 2 speedo's needed to run 2 brushless motors, but it will work. Probably easiest to use a 4 channel radio, but I am sure there is a way to do it with a 3 channel radio.
11-21-2009, 11:40 AM | #3 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Yep, it would work, a 4pk or stick radio would be needed for dig. The 55.5:1 gear ratio would probably work for ya with those motors.
11-21-2009, 11:41 AM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: Fairfield, Cali
Mine works well with 2 Tekin rs escs and 17.5t bl sensored. Using futaba 3pk.
11-21-2009, 11:44 AM | #5 |
11-21-2009, 11:44 AM | #6 |
I have a third channel on my DX3.0 only it has two positions. I want to cut the power to the motor on the rear (so i only use front dig function) Isn't 17.5 brushless to fast when its mounted on the axle. (to much wheelspeed) ?????????? I will run it with a 3s lipo I already have this set: http://cgi.ebay.com/eZrun-RC-1-10-12...item1c0dc1003c It's 106 dollar for the motor and the esc. So pretty cheap. It is a sensorless set but i have no problems with cogging Last edited by imprezapino; 11-21-2009 at 11:54 AM. |
11-21-2009, 12:17 PM | #7 |
Yes, the tekin rs and redline motors are pricy. I have limited rear dig with 3 channels 3pk. I set the rear dig mixed with steering. I have lots of torque and speed with following setup: 10t front, 9t rear 3s lipo |
11-21-2009, 01:03 PM | #8 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
This is a perfect situation for the Novak "The Dig" unit. I use one with 2 brushed Mamba Max's and its perfect... instant response tiny and easy to install.
