02-17-2010, 08:58 PM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: SOCAL
| Why not invert shocks?
I noticed some crawlers shocks are inverted but I don't see that on the LCC. What gives?
02-17-2010, 09:07 PM | #2 |
Rock Crawler Join Date: Jul 2008 Location: Hesperia
Jake and I both run them inverted (you mean upside-down right? not inverted like internal springs?). I love it.
02-17-2010, 09:19 PM | #3 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
if there is an air bubble it will affect the the performance of the shock as the piston will be sitting in the bubble in the upside down position. but with this being slow crawling that really isn't much of an issue. more towards racing vehicles. plus if you keep the shocks maintained there shouldn't be any bubbles |
02-17-2010, 09:39 PM | #4 | |
RCC Addict Join Date: Jun 2009 Location: California
dampening can fell strange if air gets sucked in....But I'm thinking about flipping mine around after this next rebuild to give it another try... | |
02-17-2010, 09:50 PM | #5 |
just do a good job on your shocks and it shouldn't be a problem. i just rebuilt my shocks cause they had a slow leak and were starting to get air in them
02-17-2010, 09:53 PM | #6 |
Quarry Creeper Join Date: Jun 2009 Location: ...
if you want to get as much wieght as low as possible then invert them |
02-18-2010, 08:23 AM | #7 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
I run my fronts upside down... and it works well. Because of my outboarded rear shocks, I haven't been able to invert them without causing some binding problems.
02-19-2010, 08:37 PM | #8 |
Newbie Join Date: Dec 2009 Location: around
i have inverted front and rear.pull out chrome balls,put the plastic ball spacers in there place and add 4 washers for the rear,cut a piece of fuel tubeing the size of the axel mounts put in metal hole file down mounts just a lil and mount shock mine work great with no binding |
02-20-2010, 06:10 AM | #9 |
Quarry Creeper Join Date: Dec 2009 Location: armpitts, CA
i was going to run them upside down but i found that my tires clear better at full turn with them on right side up. also im using internal springs and shocks are mounted right on the main chassie on delrin supports. less hard wear up top = lower COG
