Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Why not invert shocks?
Old 02-17-2010, 08:58 PM   #1
Default Why not invert shocks?
I noticed some crawlers shocks are inverted but I don't see that on the LCC. What gives?
hellacool is offline   Reply With Quote
Old 02-17-2010, 09:07 PM   #2
Jake and I both run them inverted (you mean upside-down right? not inverted like internal springs?). I love it.
Del Montess is offline   Reply With Quote
Old 02-17-2010, 09:19 PM   #3
0 0
romulus22's Avatar
if there is an air bubble it will affect the the performance of the shock as the piston will be sitting in the bubble in the upside down position. but with this being slow crawling that really isn't much of an issue. more towards racing vehicles.
plus if you keep the shocks maintained there shouldn't be any bubbles
romulus22 is offline   Reply With Quote
Old 02-17-2010, 09:39 PM   #4
Same reason why I haven't done it...Still seems like that first little bit of
dampening can fell strange if air gets sucked in....But I'm thinking about flipping
mine around after this next rebuild to give it another try...
fa1rch1ld is offline   Reply With Quote
Old 02-17-2010, 09:50 PM   #5
0 0
romulus22's Avatar
just do a good job on your shocks and it shouldn't be a problem. i just rebuilt my shocks cause they had a slow leak and were starting to get air in them
Old 02-17-2010, 09:53 PM   #6
if you want to get as much wieght as low as possible then invert them
EDGE is offline   Reply With Quote
Old 02-18-2010, 08:23 AM   #7
Y-Town Crawlers
Del Monte's Avatar
I run my fronts upside down... and it works well. Because of my outboarded rear shocks, I haven't been able to invert them without causing some binding problems.
Del Monte is offline   Reply With Quote
Old 02-19-2010, 08:37 PM   #8
i have inverted front and rear.pull out chrome balls,put the plastic ball spacers in there place and add 4 washers for the rear,cut a piece of fuel tubeing the size of the axel mounts put in metal hole file down mounts just a lil and mount shock mine work great with no binding
love2crwl is offline   Reply With Quote
Old 02-20-2010, 06:10 AM   #9
i was going to run them upside down but i found that my tires clear better at full turn with them on right side up. also im using internal springs and shocks are mounted right on the main chassie on delrin supports. less hard wear up top = lower COG
chino925 is offline   Reply With Quote
