04-13-2011, 05:31 PM | #1 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
| is thers something wrong or am i just expecting to much?
ok so when i try to climb things straight on like a step or something like that, it gets about half way up and then it stops moving, and the motor spins but the tires dont move. also it gliches sometimes going in reverse and jsut standing still. my set up is: xl5 esc, novack smart stop, castle bec, traxxas tq 27mhz radio system, a tekin 55t motor, and a futaba s9303 srevo. Is this happening becuse of my setup. Also im not really sure how to mount the antena tube so i just rapped the antena around the top bars could that be why. also my bec is set at 6v. |
04-13-2011, 05:34 PM | #2 |
It sounds like you need to tighten your slipper.... |
04-13-2011, 05:42 PM | #3 |
k does it show how to do that in the manule and if not how do i do it, is it the same as something like a slash? also how tight should it be?
04-13-2011, 05:51 PM | #4 |
Yes, on page 10, step D-03....tighten the nut labeled "A6308". You should be able to do this without disassembling the transmission, but you might need to remove the stock battery tray (if you still run that piece)... As for how tight, I usually just crank them down pretty tight....never had an issue with that setup. |
04-13-2011, 06:24 PM | #5 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Slipper.... tighten it. Also the glitch I would imagine is coming out of the good old crystals.
04-13-2011, 06:47 PM | #6 |
ok i was kind of thinking it was the radio, but im geting a dx3c next month when it comes out.
04-13-2011, 07:03 PM | #7 | |
04-14-2011, 08:09 AM | #8 |
Quarry Creeper Join Date: Jun 2010 Location: Road Trippin
04-14-2011, 08:21 AM | #9 | |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
04-14-2011, 09:58 AM | #10 |
Rock Crawler Join Date: May 2009 Location: branchville
| ditch the slipper and get the slipper eliminator for it part number LOSA3172 slippers belong on go fast toys and scalers not comp rigs |
04-14-2011, 04:33 PM | #11 | |
04-15-2011, 10:23 AM | #12 |
