07-17-2008, 07:43 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: St. John's
| New Use for a Mason Jar Lid!!
Last night I had to bust down two beadlocks and tires (Mayhems and Panthers) The first tire went on without a hitch - at 20 minutes. The second tire was a real PITA and no matter how hard I tried I could not get the whole bead to seat properly. After 2 hours (yes, 2 hours) I figured there had to be a better way. I needed to be able to hold down the entire bead while I put on the ring. But how? I tried using my hand but its really hard holding the entire bead in place with one hand while trying to fit the ring with the other. FINALLY . . . here's what I did. (Note: it took no more than five minutes to mount the tire using this method ) I found a large Mason Jar cover in the cupboard - like this one. The lock ring fit inside the jar perfectly!! I pressed the lid against the tire and pressed on it. It held the bead in place while I made sure that the entire bead was ready to be locked. By keeping a constant pressure on the lid with one hand, I was able to place the ring in place and lock it down first with four bolts to hold it and the bead in place. VOILA!!! Sorry these are not very good pictures. I repeated the procedure tonight with my old Junfac and Rock Claws so that I could take pictures. Its hard to see what is going on but its really easy to do. I know that I'll be using the Mason Jar Lid procedure from now on!!! |
07-17-2008, 08:11 PM | #2 |
That is pretty trick |
07-17-2008, 08:14 PM | #3 |
Quarry Creeper Join Date: Oct 2006 Location: Japan
Simple yet effective, great idea !
07-17-2008, 08:19 PM | #4 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
Now that's thinking |
07-17-2008, 08:47 PM | #5 |
Rock Crawler Join Date: Aug 2005 Location: Lufkin, Tx
Instead of holding on to the mason jar lid why couldnt you of just held onto the beadlock ring? That I what I do is just get the tire pretty close lined up and then push down on the ring. If there is not a spot that is seated all the way just let up on the ring a bit and push the tire in. Once the tire is in all the way around just push down on the ring and screw it in.
07-17-2008, 08:56 PM | #6 | |
By using the lid, you can see EXACTLY how the bead is fitting onto the rim, you can even push the bead into the slots on the rim with a screwdriver just to make sure all is well - and then hold it there while you bolt on the ring. | |
07-17-2008, 08:58 PM | #7 |
I wanna be Dave Join Date: Dec 2007 Location: Not here
Slick idea.
07-17-2008, 09:04 PM | #8 |
Quarry Creeper Join Date: Aug 2007 Location: Amarillo, TX
Love it..!
07-17-2008, 09:24 PM | #9 |
Rock Crawler Join Date: Dec 2007 Location: USA
yea i spent like 2 hours trying to put mine together when i first got them but no more 2 hours :P great idea!
07-17-2008, 09:35 PM | #10 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
cool now when I break out the shine when working on the crawler I will have a use for the lid that I normally just knock off the desk! |
07-17-2008, 09:40 PM | #11 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
half the people on this board don't even know what a mason jar is. Nice idea though it looks like it'd work perfectly
07-17-2008, 09:48 PM | #12 |
07-17-2008, 09:54 PM | #13 |
Rock Stacker Join Date: Jun 2008 Location: Eureka
Great Idea! Thanks for sharing with everyone!
07-17-2008, 10:06 PM | #14 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Oh now you tell me, awesome idea. |
07-18-2008, 05:49 AM | #15 |
Good idea but lose that "L" allen key and get a decent hex driver. That in itself will make the job easier. I just use the hold the ring down on the bead trick and it works just fine by starting one screw in, make sure that the bead is even, then start another screw 180* from the first. Now that the ring is partially secured and the tire bead is in place start placing the rest of the screw but do not tighten any of them until you go around a second time. This works each and every time and only takes 5 to 10 minutes (10 screws per side for Pro-Line, Axials are faster since they only have 8 screws per side). |
07-18-2008, 05:55 AM | #16 | |
Otherwise, just have alook here and I'm sure all will suddenly recognize a Mason Jar: http://en.wikipedia.org/wiki/Mason_jar | |
07-18-2008, 06:02 AM | #17 |
Pebble Pounder Join Date: Jun 2008 Location: Central Florida
Brilliant idea!! Now we need some green anodized, billet aluminum Mason jar lids :-P |
07-18-2008, 06:08 AM | #18 |
07-18-2008, 06:49 AM | #19 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Rockin' |
07-18-2008, 07:42 AM | #20 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
I've been using Small piece of 3" PVC
