Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Low Boyz 2.2 Weighted Pendulum Beadlock Wheel
Old 01-31-2010, 06:22 PM   #1
Default Low Boyz 2.2 Weighted Pendulum Beadlock Wheel
does anyone have any experiance with the Low Boyz 2.2 Weighted Pendulum Beadlock Wheel
do these wheels seem to work well or do they get gummed up and quit moving smoothly.
climbingfireman` is offline   Reply With Quote
Old 01-31-2010, 07:09 PM   #2
I had a set. They always swung freely, but the pendulums didn't weigh enough for me. They would work on a light rig, but not so great on a heavier rig. Look at the mayhem or the vanquish wheels. I think that you will be happier with those.
bivens22 is offline   Reply With Quote
Old 01-31-2010, 10:19 PM   #3
i was cheesing for a set of these wheels.. just kinda a trick set up you wont see every day. ended up getting hooked up with a set of ucw from mayhem.. liken em so far.
acuramech is offline   Reply With Quote
Old 02-02-2010, 11:17 PM   #4
i just mounted my hb rovers on a set of the low boys and i'm running a lcc,so far i like them.The only thing so far i don't like is there is no vent whole in rim,the weight set up that you can unscew to lightn up doesn't even add up to 1.0 oz so i ended up pulling the rear weight assembly out to get light enough but other then that the off set is a little wider and they look great
crazz from bc is offline   Reply With Quote
Old 02-18-2010, 10:04 PM   #5
Well that sounds to me like there needs to be a version II of the LB WP Wheels made.
#1 Vent holes
(Seriously no way to let the tires breath?! That's RC rim 101 stuff...)
#2 Pendulum/Rims with more of a Dynamic Weight distribution engineered into them.
(Every crawler is different and it stands to reason weight distro be incorporated into rim design. Otherwise Pendulum is a great idea but mainly hype if its not adjustable over 1oz.)
somoney is offline   Reply With Quote
Old 02-18-2010, 10:58 PM   #6
Wow these looked real cool but I guess I'll go for a more traditonal rim now!
Bukwylde is offline   Reply With Quote
