09-12-2010, 10:14 AM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Streetsboro
| XR10 wheels fit an AX10?
Anyone know if XR10 wheels fit an AX10?
09-12-2010, 10:30 AM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
they will bolt up, but will be a different offset.
09-12-2010, 06:18 PM | #3 |
10-01-2010, 09:15 AM | #4 |
Newbie Join Date: Sep 2010 Location: Woodward, OK
Might you know what the off set is? Or where to go to find it? Thanks
10-02-2010, 05:21 AM | #5 |
Stock AX10 wheels make the front of the XR10 11.5" wide with Rovers |
10-02-2010, 07:14 AM | #6 |
Rock Crawler Join Date: Jul 2008 Location: Dutch Oven - AZ
I think he's asking the other way around... Will an AX-10 sit a bit wider or a bit narrower than stock with the new XR-10 wheels? |
10-02-2010, 07:27 PM | #7 |
Rock Crawler Join Date: Apr 2009 Location: bend
| xr 10
i was wondering the offset. how would the xr wheels work on a llc. i have a extra set of vanquish hubs.
10-02-2010, 07:37 PM | #8 |
Quarry Creeper Join Date: Jan 2010 Location: GV
Vanquish hubs have nothing to do with xr10 wheels
10-02-2010, 08:02 PM | #9 |
10-03-2010, 04:09 PM | #10 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
From the Axial wed site. Here you can see the offset difference between our old AX10 wheels and the new XR10 wheels. The XR10 wheels measure about 3/4″ from the back of the inner bead seat to the backside of the wheel hex. The AX10 wheels measure just under a 1/4″. So, there is just over a 1/2″ of offset difference between the 2 wheels. Overall width of the 2 wheels is very similar. |
11-11-2010, 04:55 PM | #11 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
I used to use XR10 rims on my AX10. Not the best ever, if you have aluminum knuckles its better. The first one is an XR10 and the Second is a AX10 if you have the plastic hub they need to be modified, or you can get a set of axle extenders. |
11-13-2010, 11:28 PM | #12 |
Rock Crawler Join Date: Jan 2009 Location: San Gabriel, Crawlerfornia.
There is a bit of a difference there
