12-31-2011, 11:35 AM | #1 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
| Wheel weights clarification
Ok, getting a parts list for wheels and weights and such. However, I'm a little confused with the wording Weight ring: 1.9 Internal Wheel Weight Ring 43g/1.5oz (2pcs) Weights: 1.9 Internal Wheel Weight Insert 9g/0.33oz (4pcs) (for use with AX30547) The wording of the quantity is confusing me... just the way they're describing it. To me, it sounds like I should get: 4- AX30547 (if it's 1.5oz each and there're 2 pcs per pack, then I would get 3oz/wheel, right?) 4- AX30548 (.33oz each with 4 per pack, so 1.22oz/wheel, right?) (may not get if the others add 3oz each) Those numbers are correct, right, because the wording in their description throws me. Mostly when they say "To add the maximum amount of weight to a pair of wheels use (2) Internal Wheel Weight Rings and (3) Internal Wheel Weight Insert packs." Maybe someone can clarify Looking at $128-152 for my whole list(tires and wheels too) depending if I go with the separate insert weights or not. Ugh... Or if anyone has any suggestions (I was thinking of stick-on pine wood derby car lead weights as an option). I plan on running the stock wheels because I like the look of them, and 1.9 Pitbulls |
01-01-2012, 03:58 PM | #2 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| Re: Wheel weights clarification
i use these weights. there .25 oz per little square, total of 45 oz plenty for extra sets of wheels http://www.ebay.com/itm/330548817504...84.m1423.l2649 |
01-01-2012, 04:34 PM | #3 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
I just go to my local tire store when I need wheel weight and get a stick of weights with 12 of the 1/4oz sections for $1.00 each
01-01-2012, 05:07 PM | #4 |
Quarry Creeper Join Date: Dec 2011 Location: Huntington Beach
If you do not mind I will horn in here to ask a related question. I am about to order a set of 1.00" SLW wheels from Vanquish. Does anyone know if these wheel weights fit inside the recessed part of the wheel without trimming them? Or will I have to trim them to fit into this area? |
01-01-2012, 05:22 PM | #5 |
Motorcycle shops use wheel weights that are longer and narrower than automotive weights. They usually work great for narrow wheels.
01-01-2012, 05:32 PM | #6 |
| Re: Wheel weights clarification |
01-01-2012, 07:55 PM | #7 | |
| Re: Wheel weights clarification Quote:
I'm actually diving into some ideas for a wheel weight system. I think it'll be a pretty cool idea that many people would want to check out. I'll make a separate thread later | |
Wheel weights clarification - Similar Threads | ||||
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
Wheel Weights | MikeyBike | Formula Offroad | 7 | 06-24-2011 07:50 AM |
wheel weights | hpi25 | Newbie General | 2 | 02-13-2010 05:23 PM |
Wheel Weights | mikenredding | Newbie General | 2 | 11-26-2007 05:57 PM |
