05-22-2018, 05:26 AM | #1 |
Pebble Pounder Join Date: Jun 2015 Location: Netherlands
| SSD Beadlock rings
I'm running the 2.2 SSD Rock Racer wheels on my Bomber. I would like a different colour beadlock ring instead of blue or black. Does anyone know if the Vanquish original 2.2 rings will fit the SSD wheels? |
05-22-2018, 06:06 AM | #2 |
| Re: SSD Beadlock rings
Good question. I was wondering the same about the 1.9 SSD wheels - do any other rings fit?
05-22-2018, 09:04 AM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
It would be killer if Locked Up rings would fit. If anyone has an answer please post......
05-22-2018, 09:44 AM | #4 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
if none fit, I know JEC racing will make you rings however you want, just have to send him one to use as a template on the bolt pattern and pick your pattern.
06-01-2018, 01:54 AM | #5 |
Couldn't find anyone who tested this, so I'll probably order a single beadlock ring with my next order from Vanquish |
06-01-2018, 02:53 AM | #6 |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
| Re: SSD Beadlock rings |
06-01-2018, 04:05 PM | #7 |
I know LockeUpRC makes a bead lock ring that fits Vanquish wheels but I don't know about the SSD wheel. Actually, LURC might know, if you contact them they may be able to tell you.
06-01-2018, 06:56 PM | #8 |
RCC Addict Join Date: Jun 2017 Location: Canada
SSD has a different number of bolts per ring if im not mistaken. The LURC ring will not fit Sent from my Nexus 6 using Tapatalk |
06-26-2018, 01:26 AM | #9 |
As Jboucher states, the Vanquish rings have more bolts than SSD so they do not fit on the SSD wheels.
08-03-2018, 09:32 PM | #10 |
Pebble Pounder Join Date: Jun 2018 Location: Asheboro
I'm glad I ran across this post. I had the same question. Sent from my SM-G930V using Tapatalk |
SSD Beadlock rings - Similar Threads | ||||
New SSD 2.2 Proline Rings for SSD wheels | SSD | Tires and Wheels | 32 | 02-07-2017 10:56 PM |
axial beadlock rings, losi lst rings and rims cheap | andrewhendler | Chit Chat | 1 | 02-10-2008 07:47 PM |
