Narrowed Axial Racing bead lock wheels(lots of pics) finally got a set of axial racing's bead lock wheels for 40 series tires. i thought it was great when i first heard about them because the choices for 40 series wheels are rather limited. plus, i think the axial racing wheels look way more scale than the pro-line bead locks. axial also offers several different bead lock rings in many colors. i have also ordered the blue 'holy roller' rings, but they are on back order. all of the axial bead lock wheels come with grey anodized aluminum rings. check them out at- http://www.axialracing.com they can be ordered from- http://www.rcpcrawlers.com, or send a PM to rockpiledriver(yes, he has a vendor star) here is a pic of the new wheels. they also come in white, chrome, and black chrome. i opted for just plain black. http://img.photobucket.com/albums/v4...a/IMG_1162.jpg in stock form, they measure at 3 1/4" wide. too wide for moab XL's. http://img.photobucket.com/albums/v4...a/IMG_1164.jpg here are the tools i used to narrow my wheels. notice the safety glasses! http://img.photobucket.com/albums/v4...a/IMG_1166.jpg close up pic of cut off wheel and arbor. available at any hardware store. http://img.photobucket.com/albums/v4...a/IMG_1167.jpg after i have lined up the cut off wheel to the portion i want to cut, slowly start making your cut by rotating the wheel slowly against the cut off wheel. go slow and let the cut off wheel do the work. eventually the wheel will cut all the way through. make all of your first cuts on all of the wheels, then do the second cut. that way all of your wheels will be identical to each other. http://img.photobucket.com/albums/v4...a/IMG_1168.jpg what the wheel looks like after the first cut. http://img.photobucket.com/albums/v4...a/IMG_1169.jpg same procedure again for the second cut. move slowly, and be positive that the wheel you are cutting is held square and firm against the drill press table. http://img.photobucket.com/albums/v4...a/IMG_1170.jpg wheel after second cut. http://img.photobucket.com/albums/v4...a/IMG_1171.jpg detail pic of how far i cut into the reinforcement webbing on the back of the wheel. after i made the cut, i used a strong pair of side cutters to cut the webbing. http://img.photobucket.com/albums/v4...a/IMG_1172.jpg after i tacked the halves together, my wheels measured just under 2 inches. perfect! http://img.photobucket.com/albums/v4...a/IMG_1173.jpg supplies for using fiberglass to reinforce the seams. here is another thread that explains the glassing process in great detail- http://www.rccrawler.com/forum/showt...ght=fiberglass the so-cal crew has been doing this to their wheels for a long time. none of us has broken a wheel. i also like to use 30 minute 2 part epoxy. http://img.photobucket.com/albums/v4...a/IMG_1174.jpg pic of finished wheels. http://img.photobucket.com/albums/v4...a/IMG_1175.jpg after i get the moabs, i will update this post with the mounting of the tires, and the use of 'pigeonfarmboy's active super foam'. also, i need to figure out how to mount these to my thundertech clod CVD's. hopefully i'll have that solved by the time the moabs show up, and before i go to moab next weekend! |
That looks great!! |
Can't wait to see what they look like with the moabs on them. Great job. |
hinty hint hint http://homepage.mac.com/pigeonfarmbo...oftphotos.html |
Narrow Tiers Q Do you have to narrow the tires as well? |
You've done a pretty good job on yours. Pretty dang slick looking. I'm fixing to order some this evening,hopefully I might have them by this next weekend. |
Good luck......mine will bolt right up with no adapter necessary:-P :flipoff: |
Hmm sounds good I may have to try it. There are little green bb's all over my yard and my neighbors yard from airsoft wars. Post a vid or pics of them in action when you get done. |
any pics with the tire mounted??? |
Sweet, I have some 0.12's I guess I will have to pick up some more tomorrow. How many should I buy? Would 10,000 be enough for 4 Moab XL's? |
