BFG Krawler T/A's I have the BFG Krawler T/A's off the Poison Spyder Wraith and they are hard, i have played a lil bit with foams but does anyone know how to soften them?? Thanks |
Re: BFG Krawler T/A's There isn't much you can do to make the Krawler tires softer other than some techniques that racers use. For a simpler option, buying a new set of sticker tires will make it a night and day difference. Axial's sticky compound is their R35. |
Re: BFG Krawler T/A's Weight to crush the foams and tire better, v channel the inside of the foam, while your working on the foams sit the tires in simple green or another tire cleaning solution and get all the mold release and manufacturing oils out of the tire. Then just start running them and get them worn in, I like my rtr Krawlers. They work great and sound awesome on the rocks. Cheers "thumbsup" https://fbcdn-sphotos-e-a.akamaihd.n...61032749_n.jpg |
Re: BFG Krawler T/A's I want new tires but I am only 13 and dont really have money for new ones and I like how tall the BFG's are they look good on my rig, I might try the Simple green thing I have heard of it. Thanks |
Re: BFG Krawler T/A's You can soak in WD40 as well. |
Re: BFG Krawler T/A's Sipe the hell out of them with a high speed cut off tool...this adds a lot of flex and traction to any tire. |
Re: BFG Krawler T/A's Quote:
Re: BFG Krawler T/A's There are a lot of threads on how to sipe a tire. which is just cutting a tires treads to increase traction, think of a snow tire for a car, all the little grooves increase surface contact, more extreme examples are things like southern cuts, where entire lugs are removed. In your case this will do 2 things, help increase traction with the sipe but also help the tire flex because some of the support is being removed making it less rigid. A cutoff tool in a dremel works well, messy but effective. |
