Will Yeti Jr wheels accept normal 1.55 tires? I have an extra set of 1.55 mud thrashers, and was wondering if the wheels from the Yeti Jr would work. I am new to 1.55 and cant find any wheels cheaper than the wagon wheels. I'm just wondering if these Axials might work on the cheap. Thanks in advance! |
Re: Will Yeti Jr wheels accept normal 1.55 tires? Yes. 1.55 is 1.55, tire height doesn't matter. |
Re: Will Yeti Jr wheels accept normal 1.55 tires? Quote:
Re: Will Yeti Jr wheels accept normal 1.55 tires? Nope, there a normal glue on rim and rim size is 1.55. I have a yeti jr and unglued the tires to run them on beadlocks. |
Re: Will Yeti Jr wheels accept normal 1.55 tires? How did you remove the tire glue? Im thought about running beadlocks and lil'nova foams but i didnt know you could save the stock tires. Sent from my Nexus 6 using Tapatalk |
The tire glue on all 4 of mine started breaking loose. It only took a little pulling and stretching to break it all off. |
Re: Will Yeti Jr wheels accept normal 1.55 tires? I used the uncure stuff. Run a bead around the tire, let it sit for a bit, then use your thumbs and push/stretch and reapply and repeat. Some tires take longer then others depending on the amount of ca used. It takes some time so be patient but it works. https://www.amainhobbies.com/bob-smi...-bsi161/p37080 |
Re: Will Yeti Jr wheels accept normal 1.55 tires? Have guys tried the 1.55 pit bull growler? They are 4.19inch tall compared to the stock 3.25. But they can fit the lil'nova dual foams. Too tall? Sent from my Nexus 6 using Tapatalk |
I tested a set of RC4WD Mud Thrashers and I thought they were still too tall at 3.7 inches. The RC4WD 1.55 MTRs should be a good size at 3.5 inches, those are my next tires. |
Re: Will Yeti Jr wheels accept normal 1.55 tires? I went with some Slickrock wheels and small Chinese 1.9s. Looks sorta like the Yeti XL. But now even with a 3000kV 2445 it'll cog so bad in grass it needs a push start to get going. I may end up brushed again. https://uploads.tapatalk-cdn.com/201...c80f23b8d2.jpg https://uploads.tapatalk-cdn.com/201...1778b0669a.jpg |
Has anyone else ran different/bigger tires/foams and noticed it was worse on a yeti jr? |
Re: Will Yeti Jr wheels accept normal 1.55 tires? Goodyear MT/R 1.55 Boomracing terra beadlocks CI lil'nova single stage foam Perfect for the yeti Jr https://uploads.tapatalk-cdn.com/201...0522add816.jpg Sent from my Nexus 6 using Tapatalk |
