Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: tire diff on diff trucks
Old 11-24-2018, 04:23 PM   #1
Default tire diff on diff trucks
Do you guy's think the same tire can have more or less traction on 2 diff trucks. both are Axial scx10 ll. the tire is a proline Flatiron xl. it seams to have better all around traction on a rtr Rubicon than on a rtr Honcho. trucks are set up as close to the same as I can get them.
sgtlt is offline   Reply With Quote
Old 11-25-2018, 09:02 AM   #2
Default Re: tire diff on diff trucks
dont have either of those trucks tho i had same question yrs ago on the scx10 seems the jeep would b a bit heavier with the body maybe thats why u see the difference
tdevilman2009 is offline   Reply With Quote
Old 11-25-2018, 10:39 AM   #3
If the trucks weight is different the tire performance will change, good or bad depending on tire setup, and truck setup.
Another thing of note is wheelbase, ride height and wheel offset ...
lonleycreeper is offline   Reply With Quote
Old 11-25-2018, 11:53 AM   #4
Just to add it could also be a matter of the tire foams suiting one rig over the other. Weight will be the biggest factor.
HumboldtEF is offline   Reply With Quote
tire diff on diff trucks - Similar Threads
whats the Diff, between maxx 3.3 diff and revo diff? 12voltfun Traxxas Crawlers 2 06-06-2009 09:16 PM
