Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: JConcepts Ruptures 2.2 and Foams
Old 06-11-2019, 08:31 AM   #1
Default JConcepts Ruptures 2.2 and Foams
So i'm looking at buying 2 pairs of these for testing in my environment and think i've done enough research to warrant spending the cash for my SWX knock off... Environment is generally around 60f down to 40f and usually wet, being in the UK... Intended use is 90% rock and i've other brands to use where it might get softer (Swampers) or warmer (Hyrax).
My query, or plea(!), is on the foams. The Ruptures are tall at near 6" so i'd normally just buy standard 6" CI DD with soft / medium outers. However, browsing CI's site I now need to decide between 'Narrow' or 'Heavy'.
I plan on mounting these on SSD Contenders which are 33.25mm on the inner bead and 37.75 at the outer rim.
Those of you with experience with these tires & mounting on SSD would be heaven sent right now, or anything from anyone else would be appreciated as I want to pull the trigger on the purchase asap so i can get out and test!
Thanks for looking
Crawler Cads is offline   Reply With Quote
Old 06-11-2019, 10:13 AM   #2
Default Re: JConcepts Ruptures 2.2 and Foams
I run 6" CI with tuning rings removed. Medium/comp cut rear and soft standard front.
WHITE-TRASH is offline   Reply With Quote
Old 06-11-2019, 01:43 PM   #3
Am I missing something or did CI remove comp cut and standard to replace with narrow or heavy on the 6" DD? http://crawlerinnovations.com/double-deuce/2-2-6-0/
I'm thinking narrow is the same as standard but wanted to check before I pay
Do you remember what the ruptures were like to fit? Asking as I've seen a picture with an odd bead that I've not seen before...
Cheers
Sent from my Pixel 3 using Tapatalk
Old 06-11-2019, 04:52 PM   #4
Front.
https://www.rpphobby.com/product_p/cwr-1021.htm
Rear.
https://www.rpphobby.com/product_p/cwr-1025.htm
Old 06-12-2019, 12:30 AM   #5
Idiot proof, thanks trash
JConcepts Ruptures 2.2 and Foams - Similar Threads
Foams for light wraith and ruptures Motorider Tires and Wheels 3 09-21-2017 02:37 PM
Jconcepts 2.2 ruptures tire tuning for pro rigs stankulas Tires and Wheels 33 08-29-2016 09:39 PM
2.2 JConcepts Ruptures valheru Tires and Wheels 6 07-01-2016 05:08 PM
