Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Boom Racing Xtra Wide Krait!!!!
Old 09-01-2019, 11:49 PM   #1
Default Boom Racing Xtra Wide Krait!!!!
Check these out extra wide wheels.
Sent from my LGMP450 using Tapatalk
Frank211 is offline   Reply With Quote
Old 09-02-2019, 05:32 AM   #2
Default Re: Boom Racing Xtra Wide Krait!!!!
I've looked at these and almost bought them. I may still get them.
How much wider does it make the truck?
cul8tr is offline   Reply With Quote
Old 09-02-2019, 11:25 AM   #3
Would be interesting to try these out and see how the width affects side-hilling.
soze is offline   Reply With Quote
Old 09-02-2019, 06:43 PM   #4
The width is nice for some applications, LURC makes widener rings and even double-wide widener rings that fit their wheels to achieve a similar effect - and many of Gearhead's wheels are wider than the norm. As far as Boom Racing wheels go - my favorite variation on the TE37-style are these - the spokes just look so much better with that dish to them!:
And - on the opposite end of the spectrum, Boom Racing makes these super-narrow (21mm) steelies in white, black, and raw silver - perfect for those super skinny tires out there, and/or for achieving that "work truck" look:
durok is offline   Reply With Quote
Old 09-05-2019, 08:39 PM   #5
Im thinking quite a bit it seems like the hub is nearly flush with back and of the wheel.
I already have trouble stuffing the tires on my trx4 without them grabbing the body so im not sure i want it any wider.
Actually the wide version of the wheel seems to have hub set inside the wheel more
mass-hole is offline   Reply With Quote
Old 09-06-2019, 04:50 AM   #6
I guess that's to keep the hub closer to centre of the wheel or it would mess the steering up.
I have a pair of the KRAIT TE37X Gun Metal wheels and they are good quality, but the grey makes them look a bit bland. Also there are different offset hubs available, so I assume they could be used on these wider wheels.
M1tch is offline   Reply With Quote
Old 09-06-2019, 07:49 AM   #7
Moderator
JatoTheRipper's Avatar
The Hawaiin style comes to mainstream...
Old 09-06-2019, 07:17 PM   #8
this actually supports sidewalls better when the tires are not narrowed... C.I. should be bringing back the 1.5 inch wide 6 bolts back.
CM9000 is offline   Reply With Quote
Boom Racing Xtra Wide Krait!!!! - Similar Threads
Boom Racing Frank211 General Scale Talk 7 07-30-2017 08:23 PM
Boom Racing Sandstorm Krait sawhead Tires and Wheels 10 03-10-2017 05:32 PM
Xtra Speed / Boom Racing Trans Gears Hardcoretam Axial SCX-10 8 03-04-2017 10:47 AM
Boom racing jdsusername Axial RR10 Bomber 26 01-05-2016 11:08 AM
Boom Racing Vengeance General Crawlers 45 11-26-2015 04:22 AM
