Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Plastic Beadlocks. Proline vs.
Old 11-18-2019, 08:51 AM   #1
Default Plastic Beadlocks. Proline vs.
Anyone else manufacture decent plastic beadlocks in 1.55, 1.7 or 1.9 besides pro-line? I've found the 1.9 Pro-line plastics preform much better overall for my rig and wonder if there are more options.
MAGNUMB is offline   Reply With Quote
Old 11-18-2019, 08:54 AM   #2
Default Re: Plastic Beadlocks. Proline vs.
I like the Incision ones since they are fairly light and you have the option of bolting on an aluminum hub so you don't strip out the hex like on other plastic wheels.
svt923 is offline   Reply With Quote
Old 11-18-2019, 09:42 AM   #3
I have used Axial beadlock wheels for years. Never had a problem, Even when I was running big tires and big power. I also run a slipper, and set it accordingly to protect my drive train. I tend to drive with mechanical sympathy.
lonleycreeper is offline   Reply With Quote
Old 11-18-2019, 10:08 AM   #4
Originally Posted by lonleycreeper View Post
Mechanical sympathy.
Love it
Xx Losungen xX is offline   Reply With Quote
Old 11-18-2019, 01:30 PM   #5
Those look really nice! Might give these a go.
Old 11-19-2019, 02:46 AM   #6
The ones I got with the enduro sendero are pretty nice actually. If I remember correctly, they use slw hub style and element rc also offers brass and aluminum hubs.
Mounting tires is really easy with them. Installed the duratrax deep woods without any issues.
GrimmTheTourist is offline   Reply With Quote
Old 11-19-2019, 07:45 AM   #7
They are also available in black from Element RC - $21.25 for 4:
https://www.associatedelectrics.com/..._1_9_in_black/
and there's a new wheel from them called "The Ocho" that so far has no image yet, also a 1.9" - coming in black or silver:
https://www.associatedelectrics.com/...1_90_in_black/
https://www.associatedelectrics.com/..._90_in_silver/
durok is offline   Reply With Quote
Old 11-19-2019, 11:20 AM   #8
Natedog's Avatar
Axial Racing makes three different plastic beadlocks in 1.9, black or silver UMG10 style and the new Capra Raceline Monster style
Axial Racing - wheels
Pitbull RC also makes plastic beadlocks
https://pitbullrc.com/collections/wh...beadlockparent
Old 11-19-2019, 01:08 PM   #9
Nice looking wheel!
Old 11-19-2019, 01:11 PM   #10
I've found extra wheel weight doesn't help as much as i thought.
Getting better performance removing the weight and making sure the rig is balance correctly and shocks are set correctly, especially the rear ones.
Good to see some nice lightweight plastic options and saves wear and tear on the drive-train.
Old 11-19-2019, 02:50 PM   #11
Your nice to your rig. I feel like I need one of these walls in my garage
I've been using the Axial 1.9 beadlocks for a while with some gearhead rc rings. Work pretty well. Only stripped one, but I believe that was my fault for not checking the wheel nut. Even through u4rc racing, they've done well. Just not much for style options unless you dress them up with some aftermarket rings.
FordSpeed is offline   Reply With Quote
Old 12-02-2019, 08:30 AM   #12
Could found out the the new Enduro Trail Walker has 1.55 beadlocks!!
Never have seen this before.
Plastic Beadlocks. Proline vs. - Similar Threads
What plastic beadlocks Doc Harley Tires and Wheels 9 03-04-2013 01:45 PM
