Dualstage foam on bedlocks with weights on? Hi, So i wonder is it hard to fit dualstage foams on bedlocks with weights on. Recently order some foams with soft outer and hard inner cells and didnt tought about that i have weights on the rings. Also is it worth having those wheel weights? im planning to buy brass knuckle weights but its to expensive for me atm. I usually only crawl and planning to join a competition next year so i really want the ultimate car for it :) |
Re: Dualstage foam on bedlocks with weights on? It can be done fairly easily. I have used an XActo knife to trim off enough foam so it fits over the weights without distorting the foams. CI foams are pretty easy to trim. |
Re: Dualstage foam on bedlocks with weights on? Since you're EU based I suggest you look into A.L.T foams, awesome product that offers also versions for weight strips https://www.rc-hp.de/19-Zoll_1 |
Re: Dualstage foam on bedlocks with weights on? Quote:
Is it impossible to get them on without cutting? The brand is boomracing. |
Re: Dualstage foam on bedlocks with weights on? Generally speaking, rotating weight is hard on the entire drive train. It takes more energy to get the weight moving and once moving it takes more energy to stop. A much more efficient place to mount weights is on the axles as low as possible. Turns out the weight inside the wheels also makes mounting foams difficult as you can testify. |
