Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: 2.2 Aluminum bead locks + Losi RZR Rey = bad idea?
Old 03-15-2023, 09:06 PM   #1
Default 2.2 Aluminum bead locks + Losi RZR Rey = bad idea?
Greetings everyone,
I'm considering getting some 2.2 aluminum bead locks for my Losi RZR Rey. The problem is I'm not sure if the drivetrain can take the stress from the added weight or if the tires will even stay on the rims due to the centrifugal force. What are your thoughts?
Rybz is offline   Reply With Quote
Old 03-16-2023, 10:48 AM   #2
Default Re: 2.2 Aluminum bead locks + Losi RZR Rey = bad idea?
I don't think weight would be an issue, and the tires staying on would vary depending on the wheels/tires used, but most of all be mindful of the inner wheel diameter. The RZR Rey looks to have wheels with staggered diameters (with a larger inner diameter like short course wheels have) so standard 2.2" beadlocks might not clear the suspension components depending on the offset.
TooOldForThis is offline   Reply With Quote
2.2 Aluminum bead locks + Losi RZR Rey = bad idea? - Similar Threads
Losi Baja Rey and Rock Rey Aluminum Hop-ups - In Stock! RPP Hobby RPP Hobby 4 03-22-2017 04:30 PM
2.2 Bead-locks, the Good the Bad and the Best Damn 2.2 Bead-locks available! PinchFlat Tires and Wheels 36 06-11-2007 10:24 PM
