Another set of Kongs being chopped!! Well... I've cut up 2 tires so far, fairly easy but my cuts are not very straight :roll: ...... no beers in me yet, wait 'till tomorrow night when I finish cutting the other 2 up. I still have to get some ruberized glue to stick 'em back together but before I do.... I want some opinions on which tread you all think would work the best for an all around crawling tire(wet rocks, dry rocks, dirt, sandy terrain, etc). My 3 choices I'm dealing with now....... 1) It's either like Diglers which keeps the traditional "V" chevron pattern: http://img20.imageshack.us/img20/3158/Presentation3.jpg 2) Like some that were chopped up via Aussie, Ben Boynton: http://www.da-juggy.com/Tater-Tot/Kongs/on1.jpg 3) A fully directional pattern I'm thinking about but unsure of how well it'll really work: http://www.da-juggy.com/Tater-Tot/Kongs/PICT4338xx.jpg What do you guys think, shall I go with #1, #2 or #3 ?? I'm thinking #3 just to be different and see how well it works. If it sucks...it's only money I cut up right? :? 8) |
Re: Another set of Kongs being chopped!! I am thinking of doing the same thing with mine (#3) and running a mirror image tyre on the other side of the truck. /---\ . Go for #3 and do something different, besides if they slide you can just add some lugs going the oppisite direction. Ben |
Re: Another set of Kongs being chopped!! This is what I decided on. I'm not done. I may take the tread I removed and add it in between the lugs to make it more of a mud terrain style tire rather than a tractor tire. My cuts werent very clean either. I started to worry for a minute. Once I started glueing, That ended my worries. To clean up the look of the tire where the lugs meet, I came up with this design. It made the tire flex alot more. I need to run foams. I removed 1.5" from the tire http://www.rcpics.net/img/33396 |
Re: Another set of Kongs being chopped!! I'd say go for #2 but with side lugs and maybe even some extra treads in between the original ones. I think they look the best when they are that narrow and are a lot lighter too. |
Re: Another set of Kongs being chopped!! Well....after narrowing mine, I think I know what I will do the next time differently. First of all....don't go too narrow. Keep them at 3 or 3.5 inches. When the Kongs get too narrow, they get really unpredictable and the latteral stability is almost lost completely. I know soooooper skinny would look cool but be careful or you'll be relying alot on foams. I would glue mine back together like the Aussie guy did. It will make it more flexible. I've had to cut a lot of rubber off to get them more flexy. I would also use a vulcanizing patch to bond the tires back together. Basically, the same stuff Discount Tires uses to patch tires up with. Be creative but remember......different can sometimes just be... "different", not functional or better. Take the time to figure out what WORKS best for you and use that method. |
Re: Another set of Kongs being chopped!! I don't plan to make my Kongs super narrow... only remove the center section where the "V" meets. Only removing about 1/2" or so. But plan to narrow the wheels about 1.5-2". I think I'll be sticking them back together as #3... if you look at the K-Rock tire it's tread flows in the same one way direction but just the blocks are grooved and give an appearance that it's not. I plan to add extra tread, remove tread and do all the goodies... just need to finish it up by Sunday though :lol: |
Re: Another set of Kongs being chopped!! Only a half inch!?! That's hardly worth it. I'd take out a full inch. |
Re: Another set of Kongs being chopped!! Quote:
I guess I'll just see what happens in the next 24hrs :D All I need now is more beer and I can get busy :twisted: |
Re: Another set of Kongs being chopped!! #3 is different, but with the tread all going that way, it seems that if you would get on an offcamber section, it would just want to slide downhill. it would act like the boggers on side hills. but if your gonna run the right side tires with the tread going / way, i would have the left side going \ way then.that way the kind work against each other to hold up up top on the hill. just don't have all of them the same way like // or \\.. hopefully you understand what my drunk ass is tryin to say :roll: but thats just my worthless opinion, im gonna go get another beer now, go sit back in the corner and STFU :flipoff: |
Re: Another set of Kongs being chopped!! Okay.. So I'm starting to see everyone saying not to put them into the tread pattern like I was thinking about(#3 image). But what is the difference between my idea(#3) and the new Imex K-Rock tire OTHER than cutting the tread blocks???? My idea.... http://www.da-juggy.com/Tater-Tot/Kongs/PICT4338xx.jpg K-Rock.... http://www.da-juggy.com/Tater-Tot/Kongs/crawler2.jpg They both run in a single direction, it's just that the K-Rocks have some of the tread blocks cut out to give the look of going different direction... I'm I right or am I smoking something?? |
Re: Another set of Kongs being chopped!! Going with my idea, though changed slightly. One side of the tread is longer than the other. Prior to cutting my Kongs were ~ 4.5" wide.... Now my Kongs are a full 3" wide... http://www.da-juggy.com/Tater-Tot/Kongs/PICT4339.jpg I have a 1" strip of rubber lining the inside of the joint. That way I have not only the top side of the tread glued but the inside has plenty of grip too. I hope it holds up to my abuse :lol: Let's just say the more I do this the easier it seems to get. Yeah I've only finished 2 tires so far but the first sucked. Second tire went smoothly, only minor cussing when I had more glue on my fingers than on the tires :lol: 30 minutes after finishing the 2nd tire it felt really good and solid, while the first tire I did still felt like it needed another 6 hours to dry. Damn... who ever though up this tire cut'n'shut crap :? It sucks ass big time. Glad I'm half way done now and it's 10:15PM... by 1AM I should be finished with the other two, or maybe not as I have to get my azz out of bed at 6AM :evil: |
Re: Another set of Kongs being chopped!! Toyo those look friggin great. You are going to cut the tread thouugh arent you. Otherwise the tire will be very stiff right? I would like to see the wheels after you narrow them before you put the tires on. Hope you guys have fun tomorrow. I am finding some really cool spots up here in seattle to crawl. later |
Re: Another set of Kongs being chopped!! Nice. They look like they will give some good grip. Where did you buy the rubberized ca? Is the glue hard, or will it flex with the tires? |
Re: Another set of Kongs being chopped!! damn you guys make it look so easy.......I got say those are some really nice kongs......... can i just use the same super glue I used to glue mine with to glue them back together? :flipoff: |
The Marine GOOP stays flexy, somewhat rubberized. Made for marine grade rubber applications mostly. I'll find out how good of a job I've done sometime tomorrow when I crawl with them. |
Re: Another set of Kongs being chopped!! All 4 tires are now chillin'... just have to wait for the glue to firm up a bit more, by 6AM they should be ready to go!! Narrowing the rims will be later this week... I've huffed enough fumes for a year :lol: 8) http://www.da-juggy.com/Tater-Tot/Kongs/PICT4343xx.jpg |
Re: Another set of Kongs being chopped!! Looks awesome toyo!! now I just need some bigger tires so I can keep up!!! Oh, I finally glued my tires to the rims (Hadn't been to avoid breakage) went out on some of the KILLER rock piles here..... Chewed up a side gear (hex) and broke some rod ends. Maybe I dont need bigger tires? :lol: |
Re: Another set of Kongs being chopped!! :flipoff: :flipoff: :flipoff: :flipoff: |
Re: Another set of Kongs being chopped!! :flipoff: |
Re: Another set of Kongs being chopped!! Some 95% finished pictures hot off the press for ya....... Wheels are now about 1.5" wide(total width). Still need to toss in a tiny bit of foam and dump about a 1/4 pound per tire of BB's :twisted: http://www.da-juggy.com/Tater-Tot/Ko...d/PICT4481.jpg http://www.da-juggy.com/Tater-Tot/Ko...d/PICT4482.jpg http://www.da-juggy.com/Tater-Tot/Ko...d/PICT4483.jpg http://www.da-juggy.com/Tater-Tot/Ko...d/PICT4484.jpg http://www.da-juggy.com/Tater-Tot/Ko...d/PICT4485.jpg http://www.da-juggy.com/Tater-Tot/Ko...d/PICT4487.jpg |
