Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Cleaning up solder joints
Old 02-29-2008, 01:12 PM   #1
Default Cleaning up solder joints
Just wondering what everyone uses to clean up the solder joints after soldering them. The wide open ones are easy. I am wondering about the hard to get to ones where you really can't get a dremel or file into. If you look at my build in the wk section called rockstar you will see quite a few of them.
CrawlinClodKiller is offline   Reply With Quote
Old 02-29-2008, 01:33 PM   #2
small file will work.
jewelers file perhaps.
Double J is offline   Reply With Quote
Old 02-29-2008, 01:53 PM   #3
I only use a wire wheel on mine... Try not to use too much solder and it cuts down on the cleaning.
4u2nv is offline   Reply With Quote
Old 02-29-2008, 02:51 PM   #4
I find that if you use good flux and solder, it should flow flow evenly into the joint not requiring any cleanup. If I need to remove sodler from a tight join I use either a file, craft knife, drill bit or fret saw blade.
Fracture is offline   Reply With Quote
Old 02-29-2008, 03:10 PM   #5
Alot of my joints are sloppy or have alot of flux residue on them. I am still new to brazing so it is not the best looking job in the world. I do have small files and every dremel attachment known to man, plus a bunch that are not for the dremel, but still fit. I was just trying to find out if there is the purfect thing to use or what.
Old 02-29-2008, 06:25 PM   #6
Grit blasting works nice,and helps prep for painting.
Cave Dave is offline   Reply With Quote
Old 03-07-2008, 12:06 AM   #7
A kratex wheel (not sure if its kratex or cratex) on a dremel works awesome. Its like a rubber compound that has different grits and most are fine enough to not gouge or scar. You can get them in a disc or pencil tip shapes. It actually polishes things up very nice. It wont work well for removing ugly blobs of braze but does great at getting rid of the flux and smoothing.
Rocksmith Eng. is offline   Reply With Quote
Old 03-07-2008, 04:10 AM   #8
I'm with dave anthis on this one. I have a small media blast cabinet from harbor freight,I just threw my chassis in there and blasted away. then hung it up and shot some paint on it
allgm1 is offline   Reply With Quote
Old 03-07-2008, 06:10 AM   #9
Rocksmith's right ( and it's Cratex) Cratex works excellent to remove any nasty braze drips or runs. Works very well for deburring materials that create hard burrs when cutting, such as Inconel,Titanium,17-4 S.S. Everyone should have some Cratex wheels and bullet shapes for there Dremel .
