Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Setup jig for tuber build
Old 06-24-2008, 12:16 AM   #1
Default Setup jig for tuber build
This is something I am using to help me set up my next tuber build. I needed something to help me set up the attachment points for suspension links. I am using a Axial trans so why not use a set of chassis plates to help with the modifications I would like to do.
The first thing you have to do is build the bottom part of the rig, the part the trans plate bolts to. I used the chassis plates as well here to shape the tubing to match.
Next , I bolted the chassis plates to the skid plate and tubing that I made. They go on the outside with a spacer to move them out a little.
Now comes the part I like the best. If you drill all the holes on the chassis to 1/8 in. and do the same to a set of ball ends, all you have to do is use 1/8 in. rod and start to see where you want your links to be. If they don't line up with any pre drilled holes, just mark one spot on one end and drill it. Take the chassis plates off and use the one hole as a guide and flip the plates so your holes are all the same.
This could be used over and over for many setups. You could use any chassis as a base line and go from there.
Once you know where you want the links, You fab some brackets and line it all up with the steel rods and tack it together.
Here are a few pics of the jig.
motorman1600 is offline   Reply With Quote
Old 06-25-2008, 10:25 PM   #2
Very cool, that does take all the eyeballing out of it doesn't it. I think I might try this some time.
MasterShake44 is offline   Reply With Quote
Old 06-26-2008, 11:05 AM   #3
Thumbs up
I was thinking of trying something like that. Glad to see it works so well.
hankd is offline   Reply With Quote
Old 07-01-2008, 11:37 AM   #4
gas
thanks im starting to make one tonight
gas is offline   Reply With Quote
Old 07-04-2008, 01:07 PM   #5
Way cool I'm gona have to try that
Leeroy is offline   Reply With Quote
Old 07-08-2008, 06:31 PM   #6
I have an idea....Thanks!
biggin69 is offline   Reply With Quote
