02-22-2009, 09:34 PM | #1 |
Newbie Join Date: Feb 2009 Location: quitman
| Need help with fittings?
I am just curious if you guys know where i can get fitting like the ones on the piggys back shocks. I am working on a design for a simple scale hydraulic setup that will need only off the shelf parts. I have completed it on a larger scale but now im trying to locate the small fittings for the hydraulic lines. |
02-23-2009, 12:01 AM | #2 |
Pebble Pounder Join Date: Sep 2008 Location: n.e.pa
what thread are they - how much psi - i have some ideas - do you have a pump already
02-23-2009, 12:06 AM | #3 |
Newbie Join Date: Feb 2008 Location: Lakewood
I am a hydraulic mechanic and I know you are going to have a hard time finding small enough parts but you may, good thing is you don't have to worry about a lot of pressure or flow so that is on your side. I am in denver and these are the two nearest fluid power companies to me. http://www.strublefluidpower.com/home.html (local) http://www.parker.com/portal/site/PA...extfmt=default (National, I think) The fittings from parker go to 1/4" with the barbs at 1/8" I would go to a Parker Store or fluid power/hydraulic shop with the shocks they will have low pressure line and fittings there or can order them for ya. Good Luck |
02-23-2009, 12:08 AM | #4 |
They (parker) also have other fittings if you know the nomenclature to do the whole system, size permitting
02-23-2009, 08:11 AM | #5 |
They look like fittings you might find on an airbrush or something similar. Its not alot of help, but a place to start anyway. |
02-23-2009, 06:07 PM | #6 |
thanks for the help so far guys. and so far from what ive seen.. 1/4 inch is about as small as im going to find for lock fittings for any pressure tubing. Ive got a set of these shocks on order so i am gonna see if i can modify the fitting from the remote resevoir to hold around 100 - 125 psi or so fluid pressure. i did find 1/8 tubing but it starts to swell around 175 psi.
02-23-2009, 06:12 PM | #7 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
look on gardentrucking.com they have a hydraulic section...
02-23-2009, 09:26 PM | #8 |
Quarry Creeper Join Date: Apr 2007 Location: St. Louis
Check these guys out http://www.clippard.com/ I use the 10-32 fittings on a daily basis but they have fittings down to 3-56.
02-25-2009, 11:56 PM | #9 |
Quarry Creeper Join Date: Feb 2009 Location: IN MY HOUSE
Yup clippard is the way to go
