09-07-2004, 09:50 AM | #1 |
Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
| Spiral Point Taps.
I posted this in another thread to SR5Dave, but I thought it would be of interest to all. If your tapping with standard taps and having a hard time of it, pick up a set of spiral point taps. I promise you won't be disapointed! I have this set, and highly recommend it, also includes the proper drill size for each tap: http://www.use-enco.com/CGI/INSRIT?P...PARTPG=INLMK32 Smallest is 6-32 though, so be sure to order a 4-40 spiral point if needed. This lube is awsome too, for tapping and drilling: http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=940175 |
09-07-2004, 10:06 AM | #2 |
Rock Stacker Join Date: Aug 2004 Location: North Lincolnshire, UK
| Re: Spiral Point Taps.
Spiral points are normally used on machines/tapping heads. The problem with them is they have a much longer taper lead on the nose of the tap which limits the depth of thread cutting for a blind hole unless you drill much deeper - not normally a problem though. You can also modify them by grinding the nose of the tap off a few mm or 1/8inch short of where the full thread starts but still leaving enough lead on it to allow you to get a start when hand tapping but allowing a better depth of thread or a shallower hole. I usually grind a slight taper on my normal hand taps anyway to help getting a start in the hole. Only takes a few seconds on a bench grinder. PS. If anybody ever runs out of tapping lube and needs a thread cutting urgently try using WD40, it makes things alot easier than dry cutting and lessens the chance of breaking the tap. I use it alot when cutting aluminium which tends to 'stick' to the tap otherwise. |
