01-14-2011, 09:41 PM | #1 |
Pebble Pounder Join Date: Sep 2009 Location: Abbotsford, B.C., Canada
| Soldering different metals together.
I'm sure somebody here will know the answer to my question. Can I solder brass to steel? I'm adding some small tabs to a chassis and have some small brass stock on hand already. Thanks
01-15-2011, 07:52 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Yes you can. Just watch the brass. Apply more heat to metel first if you can, then to brass when steel is almost to temp. I would practice first, the brass is harder to tell temp then steel just by color.
01-15-2011, 11:41 PM | #3 |
Thanks, I'll give it a try. |
