08-30-2010, 02:06 PM | #1 |
| MAPP Gas Being Phased Out
So I am starting to get all the stuff together to start brazing and after doing some reading I found out that MAPP gas is being phased out. It is being replaced by "Max Power Propylene" or "MAPP/Pro" depending on who is selling it. The new gasses burn much colder and I am wondering what my best bet is as far as fuel. Temps: Propane: 3450F Max Power Propylene: 3600F MAPP: 5301F So the new gas is not much better than propane... |
08-30-2010, 02:59 PM | #2 | |
"MAPP'' has been gone a while now .... Quote:
Ive been using the Benzo stuff for quite a while now and havrent had a single probelm with it. Well atleast for building frames and things it works out fine. | |
08-30-2010, 03:11 PM | #3 | |
I saw that same article later but wanted to make sure before getting some that I was getting the right stuff. | |
09-22-2010, 09:20 AM | #4 |
Rock Stacker Join Date: Sep 2010 Location: Calahoo, Alberta
| Around here the propylene seems to cost twice as much as the propane. Is it worth the extra cost just to get the slight temp increase? Do I need to move to oxy/acetylene? I'm looking to braize steel w/ silv and flux.
09-23-2010, 12:47 PM | #5 |
Rock Stacker Join Date: Dec 2009 Location: Clemson
There is no reason you can't silver braze steel with propane. That 150* won't make much difference. Keep in mind that the flame control is not near as nice as acetylene, MAPP, or propylene because propane loves to spread out. As a correction to the original post, 5300*F is for a neutral MAPP/oxygen flame. It never burned hotter in atmosphere than the new "Max Power Propylene" stuff (~3600*F). Now, if you can find a gas that burns at 5300*F in the atmosphere without a near-nuclear explosion, you could be about as rich as the guy who figures out how to weld aluminum to steel. |
09-23-2010, 01:26 PM | #6 | |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
http://www.esabna.com/us/en/educatio...m-to-Steel.cfm anyway. good luck with the original topic. | |
09-23-2010, 01:49 PM | #7 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
Now I am a little confused. I thought forever everyone said use MAPP; don't even try it with propane because it will take way longer, but now with Map/Pro being the "best" option next to welding, and only a few degrees more than the propane, will the Map/Pro just take forever to heat the joint up? Will a propane torch head work on the Map/Pro bottles? |
09-23-2010, 08:20 PM | #8 | |
The main thing most people miss is the distinction between MAPP in atmosphere and oxygen. There is a huge difference. MAPP in atmosphere gives a slightly hotter flame than propane, and it gives a huge increase in the BTU value over propane due to the more potent gases (mostly propylene). So while the temperature difference is negligible, the output is significantly better. Now oxy/MAPP is a completely different critter. That gives you the lovely 5300*F flame, with a BTU approaching oxy/acetylene, and a fine point for accurate heating. It is acceptable for light cutting and welding along with most brazing jobs. In a nutshell: propane and MAPP/MPS can both be used to braze without oxygen, but it isn't easy. MAPP will be quicker and prettier than propane. Propane, MAPP, propylene, acetylene, and a number of other gases can all be combined with oxygen to braze, weld, or cut metal of any thickness you care to use. The oxygen bottle is considered "ideal" because it takes very little time to heat the steel and melt the bronze/silver, and the flame is highly controlled both in size and intensity (note that the temperature is constant for each gas). Getting straight propane or MAPP to properly heat the steel and melt/wick the braze is an exercise in frustration, but it can be done. Hopefully that is at least as clear as mud. I've seen those bimetallic inserts before. They are ideal for production work, but the chemical bonding process isn't exactly something that can be done in a regular shop. Maybe that was a poor analogy. | |
09-24-2010, 10:24 AM | #9 |
Rock Stacker Join Date: Jun 2010 Location: wnc
oxy/ acetylene is the only way to go in my book.. much hotter and more controllable than any mapp gas combo..
09-24-2010, 05:05 PM | #10 |
I appreciate the helpful response, and it should help with anyone searching map/pro or even mapp. (Thanks for not simply posting telling me to search) I'm just getting ready to finally do some brazing on my scale project, and want to make sure I am not wasting time or money with the stuff. Last edited by monkeyracer; 09-24-2010 at 05:11 PM. |
09-24-2010, 09:02 PM | #11 | |
You'll be just fine with a regular MAPP torch, particularly with the new swirl flame. It isn't quite the same point-and-dip process as oxy/acetylene, but shouldn't take too much time to learn. | |
09-25-2010, 06:31 AM | #12 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
Ha Ha I read in a thread on here a month or so ago about the Mapp gas phase out. I ran out to my local Ace hardware to scoop up their remaining Mapp gas units so I wouldnt get caught short for future builds. So just the other day Iam out in the shop and go to move my treasured Mapp bottles and I happen to read the bottle, and its the new Mapp/Pro gas . I then look at the bottle that I have been using for the last 6 months and its a Mapp/Pro bottle also. No worries thought it works just fine as far as enough heat is concerned. All I know is that it will get the 3/16 tube I use RED hot pretty quick if Iam careful. Have fun its a blast to braze things up for a project.
09-29-2010, 08:36 AM | #13 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
I'm lucky, I inherited my Victor torch from my dad when he upgraded to a big setup like you'd see on an oil rig. I finished up my last project with a MAPP bottle because I ran out of O2 late on Friday nite (no welding supply open until Monday morning) and I sure did miss my real torch. MAPP seems like a pain in the butt once you're used to a real oxygen/acetelyne setup... | |
12-22-2010, 05:19 AM | #14 |
Newbie Join Date: Dec 2008 Location: Augsburg
Over here in old Germany MAPP Gas is in supply Look here: http://shop.ebay.de/i.html?_nkw=roth....c0.m270.l1313 Yours, Martin |
12-22-2010, 09:26 AM | #15 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i had an old black bottle of plain ol propane hanging around and used it up on brazing my tube frame just fine , might have taken 5 seconds longer fer each joint i had to braze ......bob .... |
01-02-2011, 12:01 PM | #16 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
| Why? I do this all the time because I don't want to burn up my old Mapp gas to light my charcoal grill, etc. ( I use a torch to light the grill- works great) I only use the Mapp when I fab. I also have worked with plumbers who would switch from propane to mapp with the same torch head.
01-02-2011, 12:17 PM | #17 | |
01-03-2011, 04:27 AM | #18 |
Quarry Creeper Join Date: Jul 2010 Location: netherlands
acetylene has a higher flame temperature (3160 °C, 5720 °F) im going for a oxy-acetylene setup. 10, 20, 30, 40 litre tanks are no problem for me to get.. |
