brazing To start off with I have searched and watched the videos. I also know I'm using too soft of solder(plumbers solder). Now the problem, I have got a roll of uncoated brake line from the parts store. This stuff will not solder or weld! I have sanded the joints, solvent cleaned,fluxed, and heated to varying degrees of temp. and the solder just sits on it. With my thumb nail I can scratch it off. I also for giggles went to the garage to weld it and that wouldn't even stick( either burned through or sat on top). Any help would be appreciated. Oh yeah I'm currently using propane for ease of use, I have an oxy/mapp setup also. I just haven't used it because I'm really unfamiliar with torches. |
I hate brake line. I only use this stuff. |
If I am not mistaken plumbers solder is only meant to stick to copper lines. I think that is your problem. A friend of mine works in HVAC and he got me my silver solder, they use it occasionally to join copper pipes to steel if the company puts steel fittings on the units. Also, most brake line has some form of coating on it. Some has the green coating and some is galvanized (still silver), either way you have to get that off of there for anything to stick to it. As to why you couldnt weld it, I cant say. What wasnt working about it and what kind of welder do you have? |
my welder is a Century 80gl, however, I have hopes to rob off it to get my Lincoln pro-mig 140 up and going. Also I picked up a new solder from TSC today, its called Bernzomatic metal solder, not plumbing solder. Did a quick little test, and seemed to bond ( a whole better than my other stuff) to my brakeline. Ok on the strength, I think. I could pull it apart, however it took a little effort. |
Do yourself a favor and get some Harris silver solder in 45 or 56 and some of their white flux. Works like a charm, no use trying to put a square pin in a round hole! |
You won't pull one of those joints apart. |
watched the vids, however my local welding shop says harris is just a name and they have an equal product. its just gonna cost around $60 for a 3oz spool. They also are suggesting me to use a liquid flux verses the paste, and yes I did tell them what I am doing. Did I get someone that doesn't know what's going on, or is this a process that can be achieve from more than one direction? |
Im sure there are other silver solders out there that are similar to the Harris stuff just make sure it is a high silver content (at least 45%) and it should be fine. Here is 3T.O. for $85 shipped thats a decent deal (http://cgi.ebay.com/3TO-45-HARRIS-SI...#ht_3982wt_905) They also sell packs with 1T.O. with the correct flux if you can find one of those. I know AirGas carries Harris if you have one locally. Also I think Lincoln bought Harris so they may be selling it as Lincoln now. |
I use the Harris with the flux already on the stick and buy it on a tube of 3 sticks. I have beat the snot out of my brakeline chassis and not as much as a crack. Get the Harris, you can't go wrong. |
I brazed for my first time saturday night while drinking a few bears and all I can say is use the Harris Safety Silv 45 and flux and you are golden. Were ever the flux is the brazing rod will flow rite into it and the joints are super strong. |
;-) Did you chop, blend and juice yourself or pick up a six pack locally? Kodiak Ale? or a Grizzly Lager? Next time a good ole beer may be tastier..... although..... I may be wrong, I never had myself a nice cold bear! ;-):) |
i use harris safety silv 45 solder and stay-silv flux paste and have never had a problem.here is another short vid of me doing a ladder rack on a scaler i just sold. http://i306.photobucket.com/albums/n...Picture449.jpg only takes a few seconds.clean it good,apply flux,heat tubing until it gets a little red,apply solder for a cpl secs,remove heat and let it cool,DONE. I use 3/16" brakeline with coating from advanced auto parts and it works good.just gotta clean it good.:mrgreen: where ever flux is added the solder will RUN and that is it.you cant hardly break the joint. |
1. IF you're building and selling stuff to members buy a vendor star. 2. I can't imagine why you be building crap to sell to people after the mess you just got your self out of what ... like two months ago? 3. Looks like you need a new surface to work on, that shit looks nasty. |
I sold the scale truck.didnt build the rack for someone. and yes sir,it is a cast iron plate I use.:oops: |
my first brazed cage i just brazed forr the first time and paid attation to what people said and watched some vids. silver solder 45, silver solder paste, the t4000 kit from home depo like 40bucks helping hands from habor freight. after like the third braze it was really easy thanks to everybods info on this site i made a really cool cage at least i think so. here is a few pics tell me what u think:flipoff: sorry the pics are REALLY BIG http://i34.photobucket.com/albums/d1...erbarecage.jpg http://i34.photobucket.com/albums/d1...y/monster1.jpg http://i34.photobucket.com/albums/d1...ertopshade.jpg http://i34.photobucket.com/albums/d1...monster4ws.jpg http://i34.photobucket.com/albums/d1...onsterflex.jpg http://i34.photobucket.com/albums/d1...stertopsun.jpg |
That looks good"thumbsup". I guess I'll have to take the plunge and just order the harris silv. |
