04-20-2007, 03:13 PM | #1 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
| breaking cutting wheels
when i was making a clouple i.e 3, mounts out of plastic during the time i had broken 5 cutting wheels on my dremal:-( is there something iam doing wrong? and is there a right or a wrong way to cut using a dremal? thanks in advance for the help -chris |
04-20-2007, 03:24 PM | #2 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
When you were cutting was the cutting wheel in between the material? If so you probably just twisted inside the cut or something and broke it. I don't beleive there is a right or wrong way to use or hold a dremel. when cutting just keep it straight as possible. Besides you can buy more and they are under $10. what really sucks is when you used the container for something else and they are scattered all around the work bench and a crap load of stuff is on top of them. Then time to get another out and where the hell are they.? |
04-20-2007, 03:49 PM | #3 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
at least it wasnt a bigger wheel, i have had 2 break on me before(one was on a 4" electric grinder, the other an air die grinder), they dont break they explode anyway you might have pinched it and it just broke. dremal wheels suck. |
04-20-2007, 03:50 PM | #4 |
04-20-2007, 03:58 PM | #5 |
Rock Crawler Join Date: Apr 2004 Location: toolsa, jokelahoma
i try to make a few light passes at first instead of trying to cut all the way through at once... they still break every once in a while,
04-20-2007, 04:08 PM | #6 |
04-20-2007, 04:23 PM | #7 |
Rock Crawler Join Date: Jan 2007 Location: Long Island NY
Sounds Like Your Using The Thinner Discs IF They Keep Breaking Double Them Up |
04-20-2007, 04:25 PM | #8 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
they have reinforced ones. if i were you i would wear saftey glasses when using dremel cutoff wheels. dont ask.
04-20-2007, 04:57 PM | #9 |
Pebble Pounder Join Date: Apr 2006 Location: grand rapids
Yes, the thin discs are not good for much. You need the fiber reinforced ones. Also, don't forget about the hacksaw when cutting plastic. Fast cutting and cheap. With a little practice it will cut straight.Drilling the corners and cutting into them will give a nice radius to inside corners. As long as I've already changed the subject. Most woodworking tools work good for cutting plastic. Tablesaw, chopsaw, router, belt sander, etc. |
04-20-2007, 05:00 PM | #10 |
Quarry Creeper Join Date: Oct 2006 Location: Simi Valley, CA
04-21-2007, 01:28 AM | #11 |
there the thin ones. i didn't even think about doubleing em up and yes i where saftey glasses first time it broke flipped up and hit me in the neck left a little mark the shape of a shatterd egg |
04-21-2007, 01:33 AM | #12 | |
Pebble Pounder Join Date: Feb 2007 Location: Evergreen
*l* Get the little quick connect thingie with the biger discs They are much better | |
04-21-2007, 02:11 AM | #13 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Fiber wheels is the only way to go.
04-21-2007, 08:21 AM | #14 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
I believe you can also soak them in automatic transmission fluid and it helps them not break. I'm not sure if that holds for the fiber-reinforced ones or just the cheap thin ones.
04-21-2007, 02:47 PM | #15 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
you're going to fast, the plastic melts and binds up the blade. do a couple of scores across the top of the line you wan tto cut to remove small amounts of the plastic, then slowly cut through the entire piece. also if youre dremel is variable speed try slowing it down some
04-21-2007, 09:06 PM | #16 |
04-23-2007, 03:03 PM | #17 | |
Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
04-27-2007, 05:38 AM | #18 |
Newbie Join Date: Apr 2007 Location: hopkinsville
i went to lowes and saw they had a dimond blade cut off wheel it worked great better than the fiber cut off wheels and i was cutting plastic
04-29-2007, 08:57 AM | #19 |
Newbie Join Date: Apr 2007 Location: Woodbridge
Make sure that when you cut, the Dremmel isnt binding. Also, ive found that pushing too hard while cutting can make the wheels break easier. Basically, go nice and slow and steady to ensure you dont snap as many wheels.
04-29-2007, 11:47 AM | #20 |
Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
I picked up the steel saw blade which works very well for plastic. You just have to take it slow so you don't melt the plastic. The blade also works well on tires.
