09-02-2005, 06:37 PM | #1 |
Newbie Join Date: Aug 2005 Location: lake geneva
| 4 or 3 link on a stock maxx frame?
can a 3 or 4 link set up work on a stock maxx frame? If anyone has one plz post a pic plz. thanks in advance for any info!! |
09-02-2005, 06:39 PM | #2 |
oh and i for got i CAN do some mods to make it work if it works. |
09-02-2005, 07:48 PM | #3 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
you could but it would require mounting some aluminum bits to actually mount the links. I'm doing an NVT(No Vertical Travel) chassis which will have a cut down stock chassis with some aluminum extensions to mount my 2 link and the pivot.
09-02-2005, 08:10 PM | #4 |
ok i am gunna ask (feels stupid) how dose a two link work then?
09-02-2005, 08:13 PM | #5 |
Quarry Creeper Join Date: Feb 2005 Location: Grand Forks
it doesnt...havent seen anything liek it before.
09-02-2005, 08:50 PM | #6 |
i guess i will just have to try it to see if it works. if not ill try to make a frame. dose anyone know where i can get that rock raider chasssi? i cant find one any where. |
09-02-2005, 08:52 PM | #7 |
i can get you a nice maxx chassis.. pm for details.
09-03-2005, 02:02 AM | #8 | |
09-03-2005, 08:47 AM | #9 |
ahh i see. but why no virtical travle?
09-03-2005, 01:31 PM | #10 |
Its simpler, and I'm not jumping the maxx anymore, so no need for up or down travel. I may just do a regular old 3 link, but I like being diffrent, and I already have some of what I need to make an NVT system.
09-04-2005, 04:46 PM | #11 |
Newbie Join Date: Aug 2005 Location: Salem
| 2 link
you could run a 2 link. you need sppecial links though. ive seen them before. one end forks off into 2, like a y or v shape and both ends are connected to the axle for stability(the axle cant move back and forth) and another setup could consist of 4 links but mounted to be used like a 2 link. one end of each link connected to the axle(top and bottom for the stability) and the other ends are mounted exactly next to each other, width wise.
09-04-2005, 05:09 PM | #12 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
but if you do the 2 link with them breaking into a Y, what is to stop the axle from going side to side then? |
09-04-2005, 09:17 PM | #13 |
ok thanks 4 the info!! can some one post some good pics of how all links up to the axel please??!! thank you all again very much!! |
09-05-2005, 08:59 PM | #14 |
panhard bar and it would still move with a 4 link wouldnt it? and what i meant by the axle moving back and forth was that it would not twist back and forth, like how a 4 link setup would be if you only had the top or bottom links connected, theyd go everywhere.
09-06-2005, 04:13 AM | #15 |
well i knew what ya meant cause you side back and forth. but you would need a panhard as you said to keep it going from side to side. but that would make it into a 3 link then if you do a 4 link the right way, that axle will not move at all. I run a double triangulated setup on mine, and it doesn't move a bit. no need for a panhard
09-06-2005, 06:08 PM | #16 |
well thanks for the info but........ i have decided to make a custom boxed frame all milled out. i wish i could post pics !!!! but anywhoo i got out of that fase so now all i need to do is wate for the link ends pecies. |
