09-15-2012, 10:04 AM | #1 |
Pebble Pounder Join Date: Aug 2012 Location: repentigny qc
| summit steering
hi guys i just got a summit and i find then he dont turn realy got is it cos the tires are to big or just cheap servo ?
09-17-2012, 05:59 PM | #2 |
Rock Stacker Join Date: Jun 2012 Location: Indianapolis, IN
| Re: summit steering
could be due to a couple things: - batts not fully charged - servos not 'aligned' properly (is there any humming when you're not turning the wheel? when you lift the truck off the ground?) - are the servo hot?? those are the main things i can think of... the stock servos arent the strongest nor most durable by any stretch... it also depends on under what conditions you are experiencing these issues; is the truck sitting on a flat surface or while the tires are lodged against an object (like when rock crawling)?? The internal gears are just plastic so after time and use they can/will wear and strip/fail. there are upgrades available more powerful with metal internal gears when you get to that road... |
09-17-2012, 06:00 PM | #3 |
| Re: summit steering
oh and congrats on the new summit!!!
09-18-2012, 01:17 AM | #4 |
| Re: summit steering
thx for tips i have find my probleme its was the rod that go from the horn to the steering ;) i have thihted them and now i got plenty of steering as on my savage flux but i like my summit way more then the savage on my 6s set up it totaly insane lol insta flip on place il just need to order the mip drive shatf i have already the mip dogbone i stripped the stock plastic in 5min on 6s lol
09-18-2012, 06:03 PM | #5 |
| Re: summit steering
are you running 6s on the stock esc?!!
09-18-2012, 08:09 PM | #6 |
Pebble Pounder Join Date: May 2012 Location: muscatine
| Re: summit steering
you need to stop doing back flips
summit steering - Similar Threads | ||||
new member, white summit, steering block woes | gus310 | Traxxas Crawlers | 3 | 06-19-2013 08:30 AM |
Summit burning up steering servos | M-1028 | Traxxas Crawlers | 7 | 09-29-2009 02:16 PM |
