12-16-2006, 03:07 PM | #1 |
Newbie Join Date: Apr 2006 Location: Commerce City
| 2.2 maxx comp crawler
Been working on this for a while, hope to have it running before the Colorado winter comp #3. front axle rear axle |
12-16-2006, 05:20 PM | #2 |
Rock Stacker Join Date: Oct 2004 Location: Santa Clarita, CA
I like the idea, but what is your axle ground clearance?
12-16-2006, 05:39 PM | #3 |
what did you use for the hub and driveshafts? cool design though |
12-16-2006, 05:54 PM | #4 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
I'm guessing you cut off the top and bottom of the maxx knuckle for clearance purposes on the wheels?? I personally wouldn't trust that mounting, but that's me.. Nice job on teh build so far though |
12-16-2006, 07:35 PM | #5 |
Pebble Pounder Join Date: Oct 2006 Location: Honeoye Falls, NY
i like it! first 2.2 maxx i have seen, i agree with twisted, but to everyman his own how exactly are you going to work in the shocks? |
12-17-2006, 12:30 PM | #6 | |
12-17-2006, 04:38 PM | #7 |
Quarry Creeper Join Date: Jan 2006 Location: Orlando
Did you bore out standard 12mm hexes for the 6mm Maxx axle? Or was it an off the shelf item you found?
12-17-2006, 09:00 PM | #8 |
Rock Stacker Join Date: Aug 2004
Good job so far..curious to see how it works out...might give the TLT's a fight
12-18-2006, 09:49 AM | #9 |
Quarry Creeper Join Date: Apr 2006 Location: sacramento
| looks sweet
12-18-2006, 10:33 AM | #10 |
Newbie Join Date: Dec 2006 Location: Milwaukie
nice i like. at first i didnt see how it was a maxx but now i c the diffs and drive line and knuckles. cant wait to c it done
12-18-2006, 05:41 PM | #11 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
that looks great would look nice on a unimog. keep it up i would like to see some of those at the next comp.
12-21-2006, 08:32 AM | #12 |
RCC Addict Join Date: Dec 2006 Location: Flatwoods
I love the way you went with it. I can not wait to see it finished.
12-21-2006, 10:56 PM | #13 | |
Made the shock mounts. | |
12-22-2006, 04:29 AM | #14 |
It's different.....But different isn't bad. |
12-22-2006, 08:03 AM | #15 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
Very innovative, I like it. Hope it holds up.
01-12-2007, 10:04 PM | #16 |
| Some updates
As it sits now. Wheelbase is a bit under 12.5. Clearence under skid plate is 2.75. Front axle is 12" at the widest point. Mostly because of the toe out to get better ackerman. Rear axle is about 11" wide. The beadlocks are made via the PVC method detailed at How-To: Functional 2.2 Beadlocks for under $30 Electrics are moped esc, traxxas receiver, and 55t Lathe engine. I cut and CA'd some allthread in the knuckles topped off with a nylock. Its held up pretty good so far. I've run about 4 or 5 batteries through it. I used an associated Stealth tranny. Drilled and tapped the outdrives. Cut some quarter inch round rod drilled and tapped. Drilled out some maxx yokes to 1/4. Servo mount Front driveshaft rear Flex |
01-12-2007, 10:08 PM | #17 |
You are planning on cutting that extra thread off the wheels right? If so, it would be better to turn them around so the round head is on the outside |
01-12-2007, 10:47 PM | #18 | |
The screws will be cut. | |
01-15-2007, 11:26 AM | #19 |
Newbie Join Date: Dec 2006 Location: Cotati
what kind of trans is in it
01-15-2007, 07:03 PM | #20 | ||
Rock Crawler Join Date: Jan 2005 Location: The Hills
There ya go: Quote:
