Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: Warn Wireless receiver fit in Traxxas box?
Old 09-08-2017, 03:27 PM   #1
Question Warn Wireless receiver fit in Traxxas box?
I've got a TRX-4 on the way, and figured it would be cool to finally have a rig with a winch. Then I started looking into adding one, and controlling it...
So there's a Warn licensed wireless winch control on RC4WD, but it's not waterproof. And I thought it would be awesome to just mount the winch receiver in another receiver box, or maybe even in the box the TRX-4 has stock. I tried looking at the Traxxas parts website for measurements, but the're not listed.
Can one of you guys who has a TRX-4 let me know if there's room in the receiver box for another module?
Can anyone else who has a Traxxas measure your receiver box inside dimensions?
The Warn winch receiver is listed as:
Length: 1.6in / 40.4mm
Width: 1.2in / 30.2mm
Height: 0.37in / 9.4mm
and the Tower Hobbies website lists a TQi Receiver as:
Length: 1.5in / 38mm
Width: 1.02in / 26mm
Height: 0.43in / 11mm
So I'm mostly just worried about getting the Warn receiver to fit length and width wise.
Thanks!
Dman07 is offline   Reply With Quote
Old 09-10-2017, 04:40 AM   #2
Default Re: Warn Wireless receiver fit in Traxxas box?
I buy a small ESC from Ebay (cheap) this works fine and its very small .packed it in a ballon because my stock ESC is also packed in a ballon in the stock reciever box (no room anymore) ha ha. The box is not sealed only water resistant.Traxxas recommend constantly service the rig after every deep water ride.
Traildriver is offline   Reply With Quote
Old 09-10-2017, 05:26 AM   #3
You can remove the case from the controller and it would probably fit in the stock box afterwards. I personally haven't had the best luck with those winch controllers.
rm25x is offline   Reply With Quote
Warn Wireless receiver fit in Traxxas box? - Similar Threads
Warn wireless remote and receiver don't work Derek108 Axial SCX-10 2 11-05-2014 01:59 PM
Fit receiver, light controler, and BEC in radio box EL PHANTASMO Axial Wraith 2 12-18-2013 12:49 AM
RC4WD Warn 1/10 Wireless Remote/Receiver Winch Controller Set Rckcrwlr General Scale Talk 2 12-12-2013 07:32 PM
who's using traxxas receiver box? chicostaxxs007 General Scale Talk 6 07-02-2011 10:57 AM
