Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: TRX4 lighting kit page now on Traxxas.com
Old 10-03-2017, 05:49 PM   #1
Default TRX4 lighting kit page now on Traxxas.com
looks like the lighting kit is almost here, listed as "comming soon" !
light bar, rock lights and front/rear lights with a power supply and controller part #8030 $100.00
see the full kit here
https://traxxas.com/products/parts/8...kit?t=overview
or you can buy it in pieces
https://traxxas.com/products/models/...?t=accessories
instruction pdf
https://traxxas.com/sites/default/fi...B%20-%20EN.pdf
ScoJac is offline   Reply With Quote
Old 10-03-2017, 06:30 PM   #2
Default Re: TRX4 lighting kit page now on Traxxas.com
Interesting but I see no reference anywhere that says anything about turn signals, reverse lights and brake lights. Hope they have those too otherwise I will be looking for something else.
Tako_Kichi is offline   Reply With Quote
Old 10-04-2017, 06:30 AM   #3
Personally i could live without the turn signals. reverse lights could be a deal breaker though. either way im glad to see traxxas has come out with the kit!
Decaf is offline   Reply With Quote
Old 10-04-2017, 12:18 PM   #4
from the wiring diagram and the pics. i assume it's not a light controller just a power unit. so you just have all lights on or off.
only interessting part for me are the rock lights, but before i order these i try to make my own.
Gesendet von meinem T1-A21L mit Tapatalk
magic_yeti is offline   Reply With Quote
Old 10-04-2017, 02:36 PM   #5
but how does this controller than get the steering (turn lights) and throttle (break) signal? and the
3-in-1 wire harness operates all lights with a single connection between body and chassis
has only 2 cables only on off.
Old 10-04-2017, 02:39 PM   #6
Thanks for the heads up ScoJac
It seems like the tail lights only have a singe light for each cluster, or is there more?
I'm trying to find pictures of the 1:1 with the lights on in back to compare these to.
I'm surprised to see a licensed Light bar from Rigid.
HumboldtEF is offline   Reply With Quote
Old 10-04-2017, 02:55 PM   #7
i saw one 1:1 few days ago small uppers break tail lights, small lower turn lights, left big one fog light and right big one rear drive light. some 1:1 uses clear glass others colered. dificult to find good rear pics most are front or side but forgot to make a pic was only a D90 will change mine to this but have to look what i need.
Old 10-13-2017, 05:12 PM   #8
I just got notification that RPP has the complete kits in stock, the individual parts aren't in yet though. RPP sells them for a bit less than going through Traxxas BTW
Old 10-15-2017, 09:18 PM   #9
Tough to decide now whether to sell off my nip attack kit and buy this or just make some rock lights myself and pick up a bar. I do like that the attack has the scale lighting options (turn, reverse, brake etc) but definitely want rock lights too. I'm impressed with the fit and finish of this Traxxas kit though, much less mess and prob high cg weight than the my trick rc kit.
FreakyT333 is offline   Reply With Quote
Old 10-16-2017, 12:21 AM   #10
if you wait, they will sell the rock lights separately. that's what i do, but first i try to make my own rock lights.
Old 10-16-2017, 05:30 PM   #11
Well, I ordered the complete Traxxas TRX4 kit and I have the following observations.
1. Headlights/taillights are disappointing. The headlights are bright but they do not have any LED's installed in either the turn signal lenses front/rear or the backup lens.
2. Light Bar is nice and bright. Installs neatly and has a hi/lo switch.
3. Rock Lights are nice and bright. There are two light clusters per wheel and they light up under the truck very well.
Inspector86 is offline   Reply With Quote
Old 10-16-2017, 07:22 PM   #12
Looking at the extra ports on the power supply module included with this kit I wouldn't be surprised if they plan to sell add on reverse/blinker lights. Probably with their own lighting controller to give scale function options.
Old 10-16-2017, 08:08 PM   #13
They do sell them separately on the Traxxas site. I ordered a set and waiting for them to arrive this week.
tuanies is offline   Reply With Quote
Old 10-16-2017, 11:53 PM   #14
Anyone got the package? Would like to know the voltage input to the light bar? As lots of drive got the aftermarket lights already, but we would like the get the lightbar with our own power supply. Thanks in advanced!
ricksonchow is offline   Reply With Quote
Old 10-17-2017, 12:09 AM   #15
So I saw a video of someone's install of this kit and I was shocked by the huge hole they cut in their roof to run the wires for the light bar and I though I would show how I avoided cutting such a large and obvious hole.
I separated the cage above the windshield
there's a notch in the end that lets it rotate a tiny bit
I picked out a spot under the cage that would be less obvious
to get it through the small hole I de-pinned the plugs
to de-pin pull the tab back on each wire as you gently tug it loose
Heres the view from above
and the front
Some black heatshrink or something to cover the blue wires would clean it up even more
The light bar for me is a must because the headlights are a bit on the dim side, the rock lights look promising though
Each output on the power supply is putting out 2.83 Volts
Old 10-17-2017, 07:26 AM   #16
So out of the box it does not have brake lights or reverse lights?
Old 10-17-2017, 09:08 AM   #17
There are static brake lights in the back, no reverse lights. None of the lights are dynamic though.
Old 10-17-2017, 09:47 AM   #18
Moderator
JatoTheRipper's Avatar
Expensive, but the plastic pieces and LEDs look to be high quality. You can't say that for most of the RC light kits out there. And the fact that it's a direct fit will be great for the Traxxas target audience.
Old 10-18-2017, 07:29 AM   #19
That's unfortunate, as tempting as this is being a "traxxas" part knowing the quality, the lack of desired features is leading me to wait, or search elsewhere.
TRX4 lighting kit page now on Traxxas.com - Similar Threads
CI unboxes the TRX4 by Traxxas Nova's Ark Traxxas Crawlers 4 05-28-2017 10:08 PM
Wraith Kit Build - Page by Page Video Series. FastEddy Axial Wraith 60 06-09-2015 10:11 AM
