Inexpensive sensored motor Hello, Just wondering if a 1/8 motor would fit? that seem to be the less expensive option I have found so far with a sensor. https://www.ebay.com/itm/SkyRC-Toro-...-/182996897934 https://www.ebay.com/itm/GoolRC-High-Performance-4274-2250KV-Brushless-Motor-for-1-8-RC-Car-H0L3/132374795090?epid=9003954769&hash=item1ed2271352:g :DkAAAOSwhlZYs~aK as far as ESC I was looking at something like this: https://hobbyking.com/en_us/tracksta...s-car-esc.html only down only 2s capable. I seen others ESC but they don't mention drag brake so I am not sure if that a feature. Thanks. |
Re: Inexpensive sensored motor Not sure I would run brushless in a TRX4, and 1/8 scale motor is going to find some weak points in the drivetrain. :) If your looking for a budget friendly brushed setup, I would suggest the below."thumbsup" Castle Creations 1/10 SV3 Sidewinder 12V ESC Waterproof Castle Creations 1/10 SV3 Sidewinder 12V ESC Waterproof http://cdn3.volusion.com/7z62e.xvk6w...jpg?1509388456 Brood 35T Intensity Team Brood Racing :: Crawler Motors :: Machine Wound Motors :: Intensity http://www.teambrood.com/store/INTENSITY_450.jpg or Holmes Hobbies TorqueMaster Expert 540 35T Motor Holmes Hobbies TorqueMaster Expert 540 35T Motor |
Re: Inexpensive sensored motor Quote:
I have run them on 2S and 3S in anything from my 7lb Vaterra Ascender to a lightweight, Tamiya M-07 on-road car. EDIT: Here are the two biggest threads on RCC: http://www.rccrawler.com/forum/elect...wling-esc.html http://www.rccrawler.com/forum/elect...-1080-esc.html I have a feeling the SV3 is going to be forgotten and discontinued by Castle with the release of the SV4 which is significantly more expensive. |
Will be my go-to brushed ESC from now until something better comes along... |
Re: Inexpensive sensored motor Thanks for the brush setup but I thought you get better perf with a brushless system. So I guess the 1/8 can fit but would be to much? What about a 2pole motor? I also found this brushless sensored ESC from Hobbywing QUICRUN-WP-10BL60 60A https://www.ebay.com/itm/Hobbywing-Q...4383.l4275.c10 Look good maybe same perf as the 1080. |
Re: Inexpensive sensored motor Our local crawler fans like to use this Hong Kong brand: Team Powers Budget and yet good in performance and quite reliable. Team Powers XPS EL V2 45A Brushless ESC w/ LED program Card #TP-XPS/EL V2 - 45A, for 1/10 RC #TP-BLM-215100AC-V2-2100, ,(TP-BLM-215100AC-V2-2100) by Team Powers 21.5 Turn 2100KV Actinium V2 Brushless Sensor Motor |
Re: Inexpensive sensored motor Arevir, what's "better performance"? Brushed is smoother than any sensored system I tried out. You get more power with a brushless, but if you want to go fast you bought the wrong truck! |
Re: Inexpensive sensored motor Yes, for no doubt brushed motor is the smoothest. but bear in mind, you got to service your brushed motor( Change brushes and com lathe ) For trail truck ( If you are not going to comp ) then brushless motor is the top choice in my humble opinion. |
You have to decide if you want brushed or brushless. What's most important to you? |
I spent some extra and bought a Castle Mamba X esc, think the motor was going to be something to get it going then tossed in the parts as a spare. I was really surprised at the result. After some adjustments in the esc that cheap motor creeps ahead with absolutely no cogging. It has definitely encouraged me to do 2 things. First invest in a quality motor that is crawler specific and second being moving forward I will be running brushless. For me not being any top tier competitor, the startup between this set up and my 1080 with a 35t motor is not noticeable. I would even go as far as saying it is so much better, because I was able to adjust the throttle curve to make it work for my trigger pull. I think one of the best parts of the cheapo motor is given the price I was not concerned about breaking it. First thing I did was open it up, water proof the board, then Loctite in grub screws in the open mounting hole, and add dielectric grease to the opening between the board and the can. I have run it submerged in water several times, no issues and on inspection no water. I am not claiming it is now water proof, but I would say that it is water resistant enough to not worry about it. |
That ESC look like a great deal. the motor on the other side dont seem like it at that price point. The castle is only like $9 more. Quote:
In my mind it was longer run time, not having to worry about changing brushes. But in this case as slow speed is used a lot that why the sensor. The goal was not to be fast. But there is a youtuber running 6S. I guess it could handle the 1/8 on 3s the question would be would that one fit but it also have a 5mm shaft. Quote:
Sensored Brushless, I mentioned the 1080 as it was also mentioned to be a great inexpensive setup. So I figure the 1060 would be as reliable. Quote:
- I linked the wrong one before this is the one with a sensor board https://www.ebay.com/itm/Hobbywing-Q...4AAOSwA3dYcH9V |
