New SSD Portal Delete Kits Front: http://ssd-rc.com/images/trx4%20fron...ete%20main.jpg http://ssd-rc.com/images/trx4%20fron...delete%203.jpg Rear: http://ssd-rc.com/images/trx4%20rear...ete%20main.jpg http://ssd-rc.com/images/trx4%20rear...delete%202.jpg CNC machined aluminum rear lockouts CNC machined aluminum C hubs & knuckles Hardened steel stub axles 8 Degree King Pin Inclanation (KPI) Track width is reduced by 12mm (6mm each side) Reduces the ride height by 13mm Lowers center of gravity (CoG) Improves stability More details here: Front Axle Portal Delete Kit for TRX-4 Rear Axle Portal Delete Kit for TRX-4 |
Re: New SSD Portal Delete Kits |
Re: New SSD Portal Delete Kits Very cool!! Always good to have more options... |
Re: New SSD Portal Delete Kits Interesting! |
Re: New SSD Portal Delete Kits Very cool to have the option. Might want to note it is recommended to only use low gear after removing the portals. A motor can get cooked mighty fast with the incredible high 9.8:1 stock ratio in high gear without portals. At least you could hit about 35mph on 3S before it bursts into flames. :lmao: |
Re: New SSD Portal Delete Kits I'm confused. Isn't the reason the TRX4 is so popular is for the portal axles and the other unique systems like 2 speed trans and lockable diffs? If I didn't want those on my Traxxas vehicle why not just purchase a SCX10II. |
Re: New SSD Portal Delete Kits Price of each kit? |
Re: New SSD Portal Delete Kits Quote:
Not everybody stays in a square box. Look around this site. You'll see people love to change and modify things. Options are good. |
Re: New SSD Portal Delete Kits I haven't checked the Traxxas gearing options but maybe smaller pinion and larger spur can get some of the gearing back. |
Front $75 |
Re: New SSD Portal Delete Kits I don’t own a trx4 yet. Was curious what circumstances would cause you to not want to stick with portals? |
Re: New SSD Portal Delete Kits A standard rotation motor would be needed as the Titan in trx4 is reverse rotation, correct? Also, motor leads reversed? |
Re: New SSD Portal Delete Kits I’m not a portal fan so I think this is a great option. Well done SSD! Sent from my iPhone using Tapatalk |
Re: New SSD Portal Delete Kits It seems like the new Bronco body is going to be a big hit, so these portal delete kits will make folks looking for a more scale look pretty happy. |
Re: New SSD Portal Delete Kits Where can I buy both kits? |
