04-25-2015, 03:36 AM | #1 |
Newbie Join Date: Apr 2015 Location: Seaforth
| Vaterra ascender axles on scx10
Hey guys im new to this forum, i was just wondering if any one had put Vaterra ascender axles under and scx10 chassi, if so could you post pics of how you did it? Thanks Rc_rubs223 |
04-25-2015, 11:46 AM | #2 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: Vaterra ascender axles on scx10
I'm not sure if anyone has. You would need some kind of adapter for the driveshafts maybe. I know this is a Wraith, but I guess it would be a similar way to go. http://www.rccrawler.com/forum/vater...enderaith.html |
04-25-2015, 12:02 PM | #3 |
Rock Crawler Join Date: Aug 2009 Location: San Antonio
| Re: Vaterra ascender axles on scx10 |
04-26-2015, 07:36 PM | #4 |
Rock Stacker Join Date: Jun 2014 Location: Perth
You'd use vaterra drive shafts too... They use grub screws usually, but you can swap them out for the grub pin. And fit to your scx10 gbox Sent from my iPad using Tapatalk |
07-20-2015, 11:47 PM | #5 | ||
| Re: Vaterra ascender axles on scx10 Quote:
Yes, I'd use the HD Vaterra driveshafts, they are much nicer and the way they attach to pinion gear makes better driveline angles and better ground clearance. | ||
07-21-2015, 05:36 AM | #6 |
Pebble Pounder Join Date: Aug 2013 Location: United Kingdom
I know 'the scaler store' stock the parts to convert the vaterra ascender axles to run normal shafts like the scx-10 Sent from my iPhone using Tapatalk |
07-21-2015, 11:03 AM | #7 |
| Re: Vaterra ascender axles on scx10 Yes, but you don't need to use adapters, just use the two grub screws to attach Ascender driveshafts to Axial etc. tranny. That's how we did it back when crawling first started and it works great, just Loctite the two screws as usual and all good. The tranny outputs and pinions without through-holes are actually stronger, and you don't need to spend money on adapters, spend it on trail snacks or new shocks etc. instead. |
07-21-2015, 12:27 PM | #8 |
I fully understand your point...the conversation makes using upgraded driveshafts a option though Sent from my iPhone using Tapatalk |
07-21-2015, 12:28 PM | #9 |
Yes, it's a nice option. MIP's are another option, and the two splined male and female peices can fit together even though the 'u-joint' ends are different, making even more axle and transmission swap possibilities. http://www.horizonhobby.com/x-duty-c...der-p-mip14295 Last edited by Natedog; 07-21-2015 at 12:31 PM. |
07-21-2015, 03:05 PM | #10 |
There is always that option.i converted mine almost immediately as I broke the shaft....then killed 2 diffs I wish I'd have kept it now there's more upgrades.... Sent from my iPhone using Tapatalk |
Vaterra ascender axles on scx10 - Similar Threads | ||||
Dry creek Trail Run - Vaterra 1986 K5 Blazer Ascender and Axial SCX10 | eunique | Scale Videos! | 0 | 01-24-2015 09:14 AM |
Gelande II .. vs .. SCX10 (G6) .. vs .. Vaterra Ascender | Rodrigo360 | Newbie General | 3 | 10-23-2014 06:39 PM |
