06-28-2017, 06:45 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: buffalo area
| twin hammers gears in ascender
has anyone tried putting twin hammers axle gears in either the front or rear of their ascender to try to get a overdrive/underdrive? sorry to be vague. I'm really not sure what size the ascender pinion and ring gears are, so I'm not sure if the twin hammers gears would have to go in the front or the rear.
06-29-2017, 06:34 AM | #2 |
| Re: twin hammers gears in ascender
Twin Hammers gears would be way too big to fit in the Ascender axle housings. Twin Hammers ring gear Ascender ring gear As a point of reference, the TH diff has 10x15mm bearings installed on it while the Ascender has 8X14mm bearings. You can see the TH ring gear is much larger and there is not much room in the Ascender's axle housing. Of course, that doesn't even take into account the different pinion designs or room for the TH diff cup. |
06-29-2017, 08:03 AM | #3 |
Thanks for the reply. That's good information. I thank you sir.
twin hammers gears in ascender - Similar Threads | ||||
HELP: Ascender/ Twin Hammers ---> transmission swap | Wesley | Vaterra Ascender | 2 | 06-12-2015 03:31 PM |
