Hubs and Knuckles I'm in the process of installing Vaterra aluminum hubs and knuckles on my Ascender Blazer. Or spindle and carriers as Vaterra calls them. I can't seem to get the spindle to slide over the carrier while the axle is aligned in the bearing inside the spindle. What am I doing wrong? It seems as if once the axle stub end goes in, it throws off the alignment of these two components. |
Re: Hubs and Knuckles Run into the same problem each time. Turn the C hubs, get the axle shaft engaged, while keeping the shafts engaged rotate the C hubs to line up the screw holes. Hope that helps a bit. |
Re: Hubs and Knuckles Quote:
