Body post Does anybody know if Axial or any other manufacturer has the same size (thickness) body post that will fit the Ascender. I ask because I want to use a aluminum post that is the same color as my body and not have two black dots on the hood. If I could find some green ones that are the same size, it would look much better. Thanks for your input. |
Re: Body post Don’t think so, but Vaterra V100 body posts are little stronger because holes are smaller. Just set height and drill one hole slightly bigger so that screw pins barely squeeze through the hole. These maybe available somewhere in color and or aluminum. :) |
Re: Body post Thanks |
Re: Body post You're welcome! :) |
Re: Body post Could you... I dunno... Paint the body posts? |
Re: Body post If you want a clean look, why not use magnets? Some heli use them to mount canopies and if they can hold up to 3d flying, I'm sure it would hold up to crawling. Sent from my SAMSUNG-SM-N910A using Tapatalk |
Re: Body post Because his body already has holes. |
Re: Body post Quote:
Re: Body post Rc4wd TF2 rear bed mount posts are plastic but pretty strong. Also the side cab mounts posts. Might have to drill a hole or two. :) |
