08-03-2017, 03:32 AM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| 1410 motor with 5mm output shaft will this work in the TH ?
I bought it for my rock rey but have switched it so iv got it in my spares box only problem it has a 5mm shaft does anybody know if I can get pinion' for this shaft that will work with the stock TH spur ? Thanks in advance Sent from my iPhone using Tapatalk |
08-03-2017, 03:37 AM | #2 |
Rock Crawler Join Date: Oct 2013 Location: The Netherlands
| Re: 1410 motor with 5mm output shaft will this work in the TH ?
I didnt think they make 48p pinion for a 5mm shaft. However after some quick Google search i found out robinson racing makes them. Rrp2019, check amainhobbies.
1410 motor with 5mm output shaft will this work in the TH ? - Similar Threads | ||||
4 pole brushless with 5mm output shaft | LamChop | Axial Wraith | 9 | 02-17-2016 06:59 AM |
3mm motor output shaft to 5mm | maxPOWAAA | Newbie General | 10 | 02-21-2015 03:42 PM |
